Author Topic: Cherry key caps: are they interchangeable between keyboard types?  (Read 3914 times)
Offline Donut
Hi,
As the subject says. Do the different series of Cherry keyboard (G80, G81, G82 etc.) use identical key caps, or are the key caps specific to each series? (I'd specifically like to know whether I can replace key caps on a G80 series keyboard with ones from a G81 or G83 series board.)
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
« Reply #1 on: Thu, 03 April 2008, 21:04:10 »
MY switch's keycaps can be swapped with MX keycaps. That would be G81 series for the MY and G80 for the MX.
I don't know what switches G82 series keyboards use.
Offline IBI
« Reply #2 on: Fri, 04 April 2008, 16:51:46 »
MY Switches? I thought the G81 series were rubber dome types.
Owned: Raptor-Gaming K1 (linear MX)(Broken), IBM Model M UK, Dell AT102W, Left-handed keyboard with Type 1 Simplified Alps.
Offline xsphat
  • Enlightened
« Reply #3 on: Fri, 04 April 2008, 22:34:51 »
MY switches are membranes with a spring assembly on top, so yes, they are. They feel just like a membrane though.
