Author Topic: Print Screen/Alt Screen Observation  (Read 1940 times)
Offline AKIMbO
  • HHKBro
« on: Tue, 02 April 2013, 20:01:12 »
I have a Northgate Omnikey 101...and the print screen button works maybe 1 out 3 times if I spam the print screen button.  However, if I spam alt+print screen it registers every single time (no matter how fast I spam the key).  Am I missing something.  Is there an odd quirk with some select old boards?
| KBD75 (box reds)
Offline calavera
Re: Print Screen/Alt Screen Observation
« Reply #1 on: Tue, 02 April 2013, 20:03:57 »
2KRO limitation?
Offline AKIMbO
  • HHKBro
« Reply #2 on: Tue, 02 April 2013, 20:06:23 »
2KRO limitation?
I don't think so?  Spamming prnt scrn by itself is when the key only registers half of the time.  Alt+prnt screen it registers everytime.
| KBD75 (box reds)
Offline mushupork
  • I am not knowing
« Reply #3 on: Tue, 02 April 2013, 20:57:26 »
By "spam" do you mean pound repeatedly?  Maybe it is pressure related? A normal press does not work but pressing alt + print screen causes you to apply a different touch to the print screen button - one that registers?
Wanted:  Windowed capslock for a QFR
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #4 on: Wed, 03 April 2013, 01:24:15 »
Ah, I know this symptom. I'd bet it's most likely a bad switch or bad connection. Adding the Alt key changes the voltage enough to get it to register, but it's not getting enough signal alone. Sadly, I have no idea how to tell whether it's switch or connection or how to repair it.
I would presume our resident Northgate repair guru can shed more light on it. (And probably fix it for you as well.)
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline berserkfan
« Reply #5 on: Wed, 03 April 2013, 06:01:19 »
I have noticed this problem on an old keyboard of mine, where a T key may work but not a combination of keys shift T. But shift-everything else works. Alt-T also works.
It was a rubber dome/ membrane (can't tell the dif) but it puzzles me because how can the membrane be warped/ damaged such that only one combination fails to work. (It has nothing with the keys around T, for instance, which were unaffected and shoudl be affected in a damaged membrane)
