Author Topic: Clear Keycaps  (Read 2634 times)
Offline Capitalistix
  • Cherry MX Green Disciple
    • Uncanny Electronics
Clear Keycaps
« on: Tue, 02 April 2013, 23:56:32 »
Does anyone know who makes, if anyone, translucent clear cherry MX keycaps? Preferably in OEM but Ill take what I can get! Im looking for ones that are commonly seen on MX switch test pads as you can see the color of the switch below.
Offline Reomero
  • Manual breather
Re: Clear Keycaps
« Reply #1 on: Wed, 03 April 2013, 00:00:46 »
I know Signature Plastics makes translucent and clear MX keycaps. They're probably the ones you're trying to find, although they are SP profile. I can't quite remember how similar/different SP profile is compared to OEM though..
http://www.pimpmykeyboard.com/marketplace.php
Edit: Pretty sure SP profile is shorter/lower than OEM profile.
« Last Edit: Wed, 03 April 2013, 00:06:56 by Reomero »
Re: Clear Keycaps
« Reply #2 on: Wed, 03 April 2013, 00:27:46 »
Those are pretty much what I'm looking for and might have to do. Thanks! Now only if I could find them in OEM instead =o
