Author Topic: anyone heard about Zalman  (Read 10870 times)
Offline berserkfan
« on: Wed, 03 April 2013, 10:10:28 »
I'm just wondering about the Zalman Mechanical Keyboard - ZM-K500. It looks cheap. The switches - no details. I'm guessing they got a cherry red knockoff, but can't find much info.
I want to know if it is cherry compatible and if Cherry keycaps fit fine. Wouldn't mind buying and modding and fooling around with it. If I break it when opening, at least it's a Zalman, not a Filco, that I broke!
Offline Vintage
Re: anyone heard about Zalman
« Reply #1 on: Wed, 03 April 2013, 10:22:06 »
Looks like a version of the rapoo v7 which makes knockoff linear Cherry switches. I think they are in between the heaviness of Red and Black cherry switches, but they are supposed to be low quality and poorly made.
They should be compatible with Cherry mx keycaps though. The stem is very similar except for the yellow color.
If you search this site for rapoo v7 I am sure you'll get more info.
CM QFR w/ MX Reds  | Logitech G900
Offline omgFiRE
« Reply #2 on: Wed, 03 April 2013, 11:03:04 »
Kaihua PG1511 series - Cherry MX clone:
Viewsonic V1
Genius M1
Newmen GM-10
Shogun Bros. Cross Blade
Zalman ZM-K500
Rapoo V7
Specs: http://www.kailh.com/en/products.asp?Categoryid=113&rel=15
« Last Edit: Wed, 03 April 2013, 11:09:29 by omgFiRE »
White Filco Ninja Majestouch-2 Tenkeyless FKBN87M/EFW2 (Cherry MX Brown), CM Storm QuickFire Rapid SGK-4000-GKCL1-US (Cherry MX Blue)
Offline omgFiRE
« Reply #3 on: Wed, 03 April 2013, 11:37:22 »
QFR?
Offline Vintage
« Reply #4 on: Wed, 03 April 2013, 16:23:03 »
Pretty sure this is a lot cheaper that the QFR.
Offline daerid
    • Rossipedia
« Reply #5 on: Wed, 03 April 2013, 21:49:44 »
If this is a Cherry knockoff...
those guys need to stick to CPU coolers
Offline Hak Foo
  • Make America Clicky Again!
« Reply #6 on: Wed, 03 April 2013, 23:48:35 »
WRT CPU coolers, I used to really like Zalman's stuff-- had a 7000 on my old Athlon 64, and then a 9700 on my Phenom-- but they tend to be very expensive for the performance offered.  I had one of their VGA coolers on a 6800LE and it was very impressive too, but again, fairly costly compared with, say, Arctic Cooling.
Overton130, Box Pale Blues.
Offline 1391406
« Reply #7 on: Thu, 04 April 2013, 00:31:12 »
BELOW: Zalman's switch on the left. Cherry Red on the right.
« Last Edit: Thu, 04 April 2013, 00:38:22 by 1391406 »
Offline Grim Fandango
« Reply #8 on: Thu, 04 April 2013, 02:52:52 »
I only know them for two things
-Their clip on mic
-Their CPU coolers
Did not know they made keyboards.
Offline davkol
  •  Post Editing Timeout
« Reply #9 on: Thu, 04 April 2013, 04:35:56 »
-Their clip on mic
-Their CPU coolers
They don't make keyboards, it's a rebranded OEM design.
Offline berserkfan
« Reply #10 on: Fri, 05 April 2013, 22:09:36 »
yes, it is very cheap, so much that I am tempted. but the purpose of a mechanical keyboard is the pleasure in typing. a poorly made knockoff only needs one damn swtich to break or spoil, and it's all downhill from there.
Some Chinese stuff has become seriously good quality over the past 10 years. kaihua may still be cutting its teeth. I'm totally willing to consider them - once they start gaining a rep for quality.
