Author Topic: what would you do?  (Read 1292 times)
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
what would you do?
« on: Wed, 03 April 2013, 12:58:33 »
Say you just bought a keyboard knowing that it did not have the switches or LED's you wanted because no options were given for either but you really liked the setup.  What do you do when it arrives?  Tear it apart and change out the keys and or LED's or wait until after the warranty is expired?  Price under $150US.
Melvang
Offline esoomenona
  • Gnillort?
Re: what would you do?
« Reply #1 on: Wed, 03 April 2013, 13:01:37 »
I think warranty on a keyboard is overrated. Try it out. If it works, then it works, and warranty is finished. If you decide to mod it and break it, that's on you. So yes, if I wanted different LEDs and switches, it'd be time to start modding that board.
Offline Melvang
« Reply #2 on: Wed, 03 April 2013, 13:20:18 »
sounds good thats basically what I was planning on doing as soon as my clears arrive.  Just ordered 25 for my orbweaver that just arrived
