Author Topic: tenkeyless 105 key iso layout with MX blues  (Read 3086 times)
Offline malaki
« on: Thu, 04 April 2013, 07:26:22 »
does anyone know if there's a keyboard like this available?
german layout would be perfect, but any 105 key layout would do,
the only one I know  is the filco majestouch 2 tkl, are there any other options?
Offline daerid
    • Rossipedia
Re: tenkeyless 105 key iso layout with MX blues
« Reply #1 on: Thu, 04 April 2013, 07:27:28 »
tenkeyless 105 key
come again?
Offline bazemk1979
« Reply #2 on: Thu, 04 April 2013, 08:05:33 »
TKL 105 keys?????.......... you want the 10 keypad or not?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Thu, 04 April 2013, 08:09:36 »
I guess you want 88 key really? There is Ducky, CM Rapid...
Offline omgFiRE
« Reply #4 on: Thu, 04 April 2013, 08:18:03 »
May be WASD V2 some day.
White Filco Ninja Majestouch-2 Tenkeyless FKBN87M/EFW2 (Cherry MX Brown), CM Storm QuickFire Rapid SGK-4000-GKCL1-US (Cherry MX Blue)
Offline omgFiRE
« Reply #5 on: Thu, 04 April 2013, 08:19:40 »
Are you sure about ISO (88) CM Rapid with MX blues?
Offline malaki
« Reply #6 on: Thu, 04 April 2013, 08:50:33 »
yes I wrote 105 key only to make clear that I  need a iso layout,  german if possible but any other would do,
i dont think the quickfire rapid is  available with a german layout,
Offline omgFiRE
« Reply #7 on: Thu, 04 April 2013, 08:59:20 »
I think Quickfire Rapid is available in iso layout, but not in iso and mx blue simultaneously.
« Reply #8 on: Thu, 04 April 2013, 09:00:28 »
Sure there is CM Rapid in DE. There is ISO version in blues elsewhere so I don't see why not...
Offline malaki
« Reply #9 on: Thu, 04 April 2013, 09:05:52 »
i know, the red version is, but I'm looking for a mxblue keyboard
Offline malaki
« Reply #10 on: Thu, 04 April 2013, 17:04:45 »
are you sure? if there is i'd just buy it and change the keycaps
buit i cant find it
« Last Edit: Thu, 04 April 2013, 17:24:32 by malaki »
