Author Topic: Need help on picking keycaps for Keycool 84 (75%)  (Read 8640 times)
Offline viowastaken
« on: Thu, 04 April 2013, 12:04:19 »
I hope this is in the correct section...
I need to fill this board with a new set of sexy POM keys.
I'm thinking gray color would look good. I hardly ever use the backlighting so seethrough keycaps is not an issue.
Any suggestions on how i can get a layout of PBT grays to replace every key on this board, as cheaply as possible?
« Last Edit: Thu, 04 April 2013, 13:01:32 by viowastaken »
Filco Majestouch Tenkeyless Cherry MX Brown with Ducky thick PBT white/grey
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Need help on picking keycaps for Keycool 84 (75%)
« Reply #1 on: Thu, 04 April 2013, 12:40:47 »
If you want a lighter grey a hellgrau G80-1800/186* -0/-1 would get you most of the way, then get 1.25 mods and centered caps lock from an 8200 or 8113. It's probably easiest way to have full matching right now as the 1.75 shift is not available yet in aftermarket sets generally.
Otherwise if the matching right shift is not a big issue for you perhaps one of the grey PBT sets from imsto.
« Last Edit: Thu, 04 April 2013, 12:43:35 by IvanIvanovich »
Offline viowastaken
« Reply #2 on: Thu, 04 April 2013, 13:01:46 »
aah, sorry, i meant POM keys. My mistake.
edit:
But is PBT even "better" ? I don't think I have tried anything except POM/ABS and i DREAD abs.
« Last Edit: Thu, 04 April 2013, 13:08:17 by viowastaken »
« Reply #3 on: Thu, 04 April 2013, 13:21:15 »
I don't know about better, PBT feels more 'dry' than POM. Either are more resistant to wear and shine than ABS. If you want from Cherry only have black for POM and they will be L models that end in -2.
Only aftermarket POM I know of are the KBC jellies which are like pastel colors.
Offline viowastaken
« Reply #4 on: Thu, 04 April 2013, 16:19:06 »
Hm.
The filco ABS felt quite dry too, I thought. - But sticky dry. Is the PBT a similar sort of stickyness? - That was my main gripe with the ABS caps.
« Reply #5 on: Thu, 04 April 2013, 16:23:23 »
No, no sticky. Dry dry, like rocks in the desert.
Offline viowastaken
« Reply #6 on: Thu, 04 April 2013, 18:15:02 »
awesome.
Thanks very much for your insight and suggestions so far. I'm not dead set on light gray necessarily, I Just thought it would look nice.
Any other more easily, cheaper sets that you know of? as far as I could see there were no deals to be had on the cherry g80 boards with the proper layout. Most cost more than the keycool keyboard it self did.
edit: I'd absolutely consider blank keys too, if that matters.
Thanks again so much for your help, I don't think I'd have ever figured out that that cherry board sports 99% of the keys I need.
« Last Edit: Thu, 04 April 2013, 18:20:36 by viowastaken »
« Reply #7 on: Thu, 04 April 2013, 18:32:36 »
You could get 2 sets that you need to make one complete in POM for like $40ish off US ebay. Also that is really for 2 keyboards, so you could sell the switches if you wanted and possibly come out ahead. There really aren't good deals for that board sets on PBT at the moment.
« Last Edit: Thu, 04 April 2013, 18:34:07 by IvanIvanovich »
Offline sth
  • 2 girls 1 cuprubber
« Reply #8 on: Thu, 04 April 2013, 18:42:59 »
what might work is ordering a blank PBT set from imsto @ $56 (last price i saw) and then getting a set of bottom-row keys from SP in the right sizes in a color close to what imsto has. that way the entire bottom row would be uniform.
« Reply #9 on: Thu, 04 April 2013, 18:47:04 »
No need, there would be enough B profile caps for the 1x keys from the numpad to take care of it. Only thing that would be lacking is the 1.75 shift.
Offline sth
« Reply #10 on: Thu, 04 April 2013, 18:48:43 »
ah good point, i forgot those come in 105 sets.
Offline viowastaken
« Reply #11 on: Fri, 05 April 2013, 05:21:20 »
Thanks again for the continued suggestions.
I would strongly prefer to have a relatively uniform key layout in terms of color. Do you know if its possible to get that shift key to complete the imsto set? I checked his page but as far as I could see there was no particular store front or anything like that to consult. I guess I'll have to send him an email unless you already know the answer to my question :)
« Reply #12 on: Fri, 05 April 2013, 07:12:07 »
No those 1.75 shift are not available from the Asian Cherry profile PBT. Best would be to steal one from Cherry 1800 it won't be the same color but the profile will match exactly.
Offline viowastaken
« Reply #13 on: Sat, 06 April 2013, 05:00:50 »
Do you think it's possible to get that profile in a non shift key? I see some using a capslock key instead. I think I could go with a blank one if I can get my hands on one..
It seems like the old cherry keyboards, although really cool looking keys, are rather hard to procure for a fair price at this point in time. I think I might be looking into getting a set from imsto instead or something like that.
But again, I'm a bit curious about this capslock key as use for shift key. Thanks :)
« Reply #14 on: Sat, 06 April 2013, 09:14:34 »
Not really hard to find for good price if you know what you are looking for and are not in a big hurry. Most of mine I paid less than $50 for and some pretty rare ones.
Caps lock is also 1.75 so it fits, but will just have the wrong row profile. You would have to decide if it bothered you to type on.
Offline viowastaken
« Reply #15 on: Fri, 12 April 2013, 08:22:20 »
So I've just bought this G80: http://www.ebay.com/itm/251120544598?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
At 39 usd it was a decent buy but not a total steal. Now I'm just sharking around trying to find the missing shift and 1.25 mods
Thanks again for your help, I'm very excited to get my board rockin' these new caps.
« Last Edit: Fri, 12 April 2013, 08:24:13 by viowastaken »
« Reply #16 on: Fri, 12 April 2013, 08:52:29 »
11900 are nice boards, but sadly for you the short right shift is a 2.0 units. Also the top 2 rows have the B profile same as home row which may be a nuisance.
Offline viowastaken
« Reply #17 on: Fri, 12 April 2013, 10:04:09 »
The right shift was never going to fit either way, as I understood it, and the profile of the top rows should not be a problem judging by past experiences with different key profiles.
« Reply #18 on: Fri, 12 April 2013, 11:18:00 »
1800 uses the same 1.75 shift so you can get one from those fitting the Keycool.
Offline blighty
« Reply #19 on: Fri, 12 April 2013, 13:28:28 »
The 1800 profile keys work the best on the right row (del, home, pg up, pg dn, and end are all same top row profile). 3000/Filco/Leo/Ducky keys look odd with their standard profiles on the board.
LZ ergo (MX silent red) | JER - A06 (MX silent black-red springs) | Duck Lightsaver V2 (MX red) | Duck Octagon V2 (gateron clear) (lifted pads) | Duck Orion V2 (gateron red) | TKC 1800 (gateron silent reds) | Mistel MD770 (MX red with GMK silencing clips) | Realforce R2TSLA-US4-IV | Realforce R2TLSA-US4-BK | TX 75 (gateron clear) | KBDFANS 75 ("vintage" MX blues) | Kinesis Freestyle Pro (MX red) | MS Surface Ergonomic | MS Natural Ergonomic Keyboard 4000 | Filco Majestouch 2 TKL (MX black) | Phantom (Filco case) ("vintage" MX blacks | Spr1t 75% PCB x 2 (MX black and gateron clear) | Cherry G80-1865 (MX browns with black springs)
