Author Topic: [IC] Cherry MX Grey switches (linear)  (Read 27845 times)
Offline TDub
Re: [IC] Cherry MX Grey switches (linear)
« Reply #50 on: Sat, 06 April 2013, 03:57:12 »
So these are a lot stiffer then blacks correct?
Also a question about the DT wiki, are blacks (60cN) really stiffer then clears (55cN)? Are these numbers accurate? Because I use both and was under the impression that clears were definitly the stiffer of the two. Or is that just caused by the tactile bump?
Offline pexon
  • El Jefe of Sleeving
    • Pexon PCs
« Reply #51 on: Sat, 06 April 2013, 08:09:32 »
IC form coming soon. GB imminent!  ;)
Offline pexon
    • Pexon PCs
« Reply #52 on: Sat, 06 April 2013, 09:24:39 »
GB Thread posted, awaiting Mod approval
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #53 on: Sat, 06 April 2013, 10:43:27 »
These grey are 80cN so they are noticeably more force than blacks. Clears are 65cN, ergo clear could be 55cN, maybe whoever edit the wiki f*cked it up?
Offline pexon
    • Pexon PCs
« Reply #54 on: Sat, 06 April 2013, 10:53:13 »
Thanks for the heads up man.  :)
Offline Michael
  • Formerly Bro Caps
« Reply #55 on: Sat, 06 April 2013, 10:55:34 »
Aren't there 2 variant springs to MX Clears? I remember the heavier one being 80-105cN or something like that?
« Reply #56 on: Sat, 06 April 2013, 11:02:23 »
Differences comes from some measuring actuation, and some measuring bottom out forces. There could possibly be a super clear variant I suppose though I have never seen a part number to indicate so, but it wouldn't be anything common.
There is a 105cN clicky grey too, known as grey36 or MX1AB1N*, but it is quite rare.
This one linear is grey37 or MX1A21N* which by the way are these with or without pin for PCB/plate mount?
« Last Edit: Sat, 06 April 2013, 11:12:31 by IvanIvanovich »
Offline WhiteFireDragon
    • youtube
« Reply #57 on: Sat, 06 April 2013, 11:21:50 »
Where are you sourcing these? Perhaps you can also ask for more popular switch colors? Clear, white, red, and blue switches are the most popular ones according to the GH60 GB orders. Both greys and black were the least ordered switches.
Offline pexon
    • Pexon PCs
« Reply #58 on: Sat, 06 April 2013, 11:25:27 »
Will look into it, this was just an opportunity I jumped on. Will see if I can get some clicky grey and the more popular switches
Offline Jocelyn
  • 조셀린
Re: Re: [IC] Cherry MX Grey switches (linear)
« Reply #59 on: Sat, 06 April 2013, 11:26:26 »
Will look into it, this was just an opportunity I jumped on. Will see if I can get some tactile grey and the more popular switches
FTFY and Thank You :)
Offline pexon
    • Pexon PCs
« Reply #60 on: Sat, 06 April 2013, 11:29:04 »
Ooops, clicky and tactile, blues and browns... d'oh!   :))
Offline inlikeflynn
  • file not found
« Reply #61 on: Sat, 06 April 2013, 11:29:55 »
FYI you will need to PM a mod or else it will likely sit there for 12hours awaiting approval
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline Jocelyn
  • 조셀린
« Reply #62 on: Sat, 06 April 2013, 11:31:50 »
Mine have always been approved within 30-40 minutes, but it probably wouldn't hurt to PM a mod
Offline pexon
    • Pexon PCs
« Reply #63 on: Sat, 06 April 2013, 11:32:30 »
Will PM one NAOOOO  ;)
Offline Michael
  • Formerly Bro Caps
« Reply #64 on: Sat, 06 April 2013, 15:20:09 »
Where da group buy brah?
Offline pexon
    • Pexon PCs
« Reply #65 on: Sat, 06 April 2013, 15:21:19 »
Awaiting approval still, I sent a PM to a mod...
« Reply #66 on: Sat, 06 April 2013, 15:21:49 »
I want some sweets!!! C'mon mods!!
Oh and was there a limit to how many switches you can get Pexon?
Offline pexon
    • Pexon PCs
« Reply #67 on: Sat, 06 April 2013, 15:23:24 »
150 each, I think thats fair. I dont have a massive amount of switches.... we will see how it goes
Offline Jocelyn
  • 조셀린
« Reply #68 on: Sat, 06 April 2013, 15:25:30 »
150 what each, wait what? I'm confused D:
Edit - For the candy? lol
Yall can get a max of 150 switches each, until I run out
Ahhhhh, I need to context. I tried but couldn't figure it out and that sounds fair. Thanks :)
« Last Edit: Sat, 06 April 2013, 15:28:21 by Jocelyn »
Offline pexon
    • Pexon PCs
« Reply #69 on: Sat, 06 April 2013, 15:27:04 »
« Reply #70 on: Sat, 06 April 2013, 15:33:00 »
I wouldn't mind a max of 150 sweets :D I need some UK delicious! ;D
« Reply #71 on: Sat, 06 April 2013, 15:57:41 »
Just post a link to your Google form in this thread. If a mod gets mad about it, then they should have approved your GB thread...
 >:D
Offline pexon
    • Pexon PCs
« Reply #72 on: Sat, 06 April 2013, 15:58:47 »
I want it to be fair and I want to be able to keep it organised.
« Reply #73 on: Sat, 06 April 2013, 16:10:42 »
