Author Topic: How hard is it to change switches?  (Read 1208 times)
Offline Capitalistix
  • Cherry MX Green Disciple
    • Uncanny Electronics
« on: Fri, 05 April 2013, 09:45:16 »
I'm wanting to get a Poker and Im wondering how hard it is/what all would changing the switches to some cherry greens would entail? Thanks!
Offline esoomenona
  • Gnillort?
Re: How hard is it to change switches?
« Reply #1 on: Fri, 05 April 2013, 09:47:04 »
If it's a Poker, without a plate or with a plate that has openings which allow the easy removal of them, you can open the housing and switch just the stem and spring, and then replace the housing. If it's a keyboard with a plate, it becomes harder, where you have to desolder the switches on the whole board, open them up, switch them out, and the resolder everything.
Offline esoomenona
  • Gnillort?
« Reply #2 on: Fri, 05 April 2013, 09:47:30 »
Take a look at the Moose's Mods link in my signature to see me doing just that.
