Author Topic: Winless Poker/GH60 Case  (Read 1384 times)
Offline LollyWater
« on: Fri, 05 April 2013, 10:02:20 »
Anyone know of any I can buy?
Offline codyeatworld
Re: Winless Poker/GH60 Case
« Reply #1 on: Fri, 05 April 2013, 10:09:37 »
Well dirge said he made the blockers, so you can make your own with a GH60 and a regular case. Theres also some aluminum ones coming up.
http://geekhack.org/index.php?topic=39702.msg782343#msg782343
The windows keys were made by taking two pcb mount switches and removing the tops, the gold contacts and using some flush cutters to remove the plastic from around the top.  Then some squares of acrylic also sprayed.
Offline LollyWater
« Reply #2 on: Fri, 05 April 2013, 10:18:10 »
I can't believe I didn't pay attention to that. Thanks.
