Author Topic: Taeja's keycaps and WASD keyboards.  (Read 7835 times)
Offline Okyra
« on: Fri, 05 April 2013, 11:54:11 »
Hi, I'm thinking about buying my first mechanical keyboard and those keycaps caught my eye.
With them, I was thinking about buying a WASD mechanical keyboard without the keycaps, but I don't know if they fit :/
Does anyone have the answer ? I'll be grateful !
Offline Johan
Re: Taeja's keycaps and WASD keyboards.
« Reply #1 on: Fri, 05 April 2013, 12:01:47 »
They'll fit depending on if you'll using an ISO or ANSI layout.
Uh, stuff.
Offline inteli722
« Reply #2 on: Fri, 05 April 2013, 12:02:44 »
If you get an ANSI barebones keyboard, they'll fit.
Waiting for: Phantom Plate
Offline Okyra
« Reply #3 on: Fri, 05 April 2013, 12:06:18 »
I was thinking about this one so they should fit, thanks for the quick answers :)
Offline inteli722
« Reply #4 on: Fri, 05 April 2013, 16:19:14 »
That should fit fine.
Offline Rayne
  • For Science!
« Reply #5 on: Sat, 06 April 2013, 02:06:39 »
yeah they will work, that is the same keyboard and key caps set up i am currently using.
http://i.imgur.com/xwSmtRn.jpg
Offline Choiberg
« Reply #6 on: Sat, 06 April 2013, 23:22:11 »
I believe you, 'Taeja'.
Leopold FC900r - Cherry MX Black
Tray-mount 75% - Gateron Yellow
Genovation 622 Numpad - White Alps
Packard Bell 5131C - BTC Dome with Slider
Offline FraNKzZ
« Reply #7 on: Mon, 08 April 2013, 04:08:39 »
it look awesome! :D
Offline Moony
« Reply #8 on: Tue, 09 April 2013, 12:38:23 »
Where did you get your caps printed on the side like that?
Offline Lu_e
« Reply #9 on: Tue, 09 April 2013, 15:18:33 »
Side-printing comes on certain aftermarket (keep searching) keycap sets. & even some stock keyboards (Filco 'Ninja', and soon to be; CMStorm Quick fire rapid 'stealth')
Just say NO to ABS keycaps
