Author Topic: Cherry G80-3494 MX Red @ the Keyboard Company for $100'ish US Shipped  (Read 4282 times)
Offline dante
http://www.keyboardco.com/keyboard_details.asp?PRODUCT=927
At the time of posting the conversion runs a little over $100 shipped to the US.
I have no idea how long the special is for.
Offline esoomenona
  • Gnillort?
Re: Cherry G80-3494 MX Red @ the Keyboard Company for $100'ish US Shipped
« Reply #1 on: Fri, 05 April 2013, 22:07:04 »
Why is it the "new Cherry gamer keyboard"? What about it is for "gamers"?
Offline SmallFry
« Reply #2 on: Fri, 05 April 2013, 22:18:19 »
Remember the big Cherry Red push for "gamers" after blacks wore off their appeal? Yeah, that's the gamer part. -_-
Offline Larken
« Reply #3 on: Fri, 05 April 2013, 22:37:37 »
at 100 shipped, it's a decent price. I got mine at about 120ish a while back. One of the easier to mod full sized keyboards as its pcb mounted, though the flimsy casing leaves something to be desired.
| Ergodox #1 | Ergodox #2 |
Offline dante
« Reply #4 on: Sat, 06 April 2013, 00:04:40 »
I don't know how the current G80-3000/3494's stack up to the 3000's at around the time of the Das 2 - but I didn't think the Das was flimsy at all.  Not a Model-M obviously but not a house of cards either.
It shouldn't bend or anything with the light Cherry Reds.
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #5 on: Sat, 06 April 2013, 00:11:03 »
Are there custom steel backplates that can be bought and installed into these?
Offline cgbuen
    • cgbuen.io
« Reply #6 on: Sat, 06 April 2013, 02:18:06 »
Diodes in every switch, making it 6KRO. Since a lot of other Cherry keyboards are 2KRO.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #7 on: Sat, 06 April 2013, 09:30:42 »
Exactly, it's gamer since it has over 2KRO. These are a pretty good deal considering they are usually more like $120+shipping from somewhere in Asia.
Offline esoomenona
  • Gnillort?
« Reply #8 on: Sat, 06 April 2013, 09:39:14 »
I take it those are lasered caps, probably POM?
Offline dante
« Reply #9 on: Sat, 06 April 2013, 10:12:09 »
Lasered POM yes.
Offline inlikeflynn
  • file not found
« Reply #10 on: Sat, 06 April 2013, 10:12:59 »
yes & no. we have a file that can be used to make a 3000 plate, but aren't planning on adding it to the plate GB. I suppose it maybe could be added, but with just 1 being made except it to end up around $50 shipped for a single 3000 plate as they are even more massive than the 1800 plates
correct
----------- __o
--------- _`\<,_
BRAAP(>)/ (*)
Offline esoomenona
  • Gnillort?
« Reply #11 on: Sat, 06 April 2013, 10:15:00 »
I think the 3000 plates should come, just not at the moment. Let some of our wallets have a break...
Offline dante
« Reply #12 on: Sat, 06 April 2013, 10:18:25 »
I was under the impression that there was a Cherry 3000 MY switch clone of some sort that was plate mounted that could be used on the MX switch model.
« Reply #13 on: Sat, 06 April 2013, 10:36:07 »
Maybe you are thinking of underplate mod, where you remove all the MY switch from it's plate, then put it under MX PCB to eliminate flexing?
Offline Michael
  • Formerly Bro Caps
« Reply #14 on: Sat, 06 April 2013, 10:40:03 »
I think they are doing a full 3000 plate, also doing an 1800 plate.
Offline WhiteFireDragon
    • youtube
« Reply #15 on: Sat, 06 April 2013, 11:13:33 »
Dam, if only those were double shot caps. I would have bought it just for the caps.
« Reply #16 on: Sat, 06 April 2013, 11:18:08 »
They would had to have been first run from like 2009 to have doubleshot, NOS is getting much harder to come across now. Pair it up with caps from an 8113HUAUS would be a nice one though.
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #17 on: Sat, 06 April 2013, 12:01:55 »
Oh wow, that would be so amazing!!! Ughhhhh, where do I scrape up moneyyyyyyyyyyyyyyyyyyyyy?!?!?!?! Lol!!! *sigh* The woes of a poor man.
This a billion times...
