Author Topic: Could the time change the "clicky" sound of a switch ?  (Read 4111 times)
Offline Retrete
« on: Sat, 06 April 2013, 12:50:58 »
Hi! Few days ago I bought a 2nd hand (with heavy marks of use) acer 6312-ta ,like this one but with the old acer logo ;
I also have a benq 6312-ta ,exactly like the one of the top
Comparing them head to head I noticed a different "clicky" sound , acer one is softer and less noisy than the benq .
The acer kb mounts their own keyswitches , and the benq looks exactly the same but with no acer logo on them .
The benq switch ;
I've read that the benq use Alps black , that's true ? so , alps black=acer switch?
I will upload a video in a few hours , "la duda me corroe"  ;D
Deu
Re: Could the time change the "clicky" sound of a switch ?
« Reply #1 on: Sat, 06 April 2013, 13:44:18 »
The Alps Black is a different switch than the Acer switch. The Acer is clicky while the Alps with black slider is not.
The acer switches can feel a bit different depending on how hard and fast you type on them.
Offline Retrete
« Reply #2 on: Thu, 11 April 2013, 17:40:55 »
Def acer-benq 6312 switches are not the same; the proof:
Deu!
Offline BlueBär
« Reply #3 on: Thu, 11 April 2013, 19:47:25 »
Is it just me or is that white keyboard squeaking?
Offline Retrete
« Reply #4 on: Fri, 12 April 2013, 01:44:25 »
Yep, but only the spacebar, I have to fix it
