Author Topic: Micron PC 5121 keyboard switch type  (Read 7317 times)
Offline jksteger
« on: Sun, 07 April 2013, 19:32:56 »
I just purchased a Micron PC 5121 online and it's described as "clicky", does anyone have information on this model?  Thanks
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Micron PC 5121 keyboard switch type
« Reply #1 on: Sun, 07 April 2013, 21:09:49 »
Hope you didn't pay much, because it's probably a domes or maybe a foam and foil made by BTC. It sure as $hit won't be clicky.
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #2 on: Sun, 07 April 2013, 23:55:02 »
Micron 5121 == BTC 5121.
Rubber dome.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline jksteger
« Reply #3 on: Mon, 08 April 2013, 11:02:11 »
thanks, i paid 12 bucks for it.  Oh well.  I had seen on youtube where a user had a Micron PC keyboard that was some type of mechanical switch.   It seemed to be buckling spring or maybe NMB space invaders and took a shot in the dark at which model as there is not much info that I can find on them.
Any chance anyone knows which Micron PC keyboards had the clicky mechanical switches?
Thanks,
J
Offline jksteger
« Reply #4 on: Mon, 08 April 2013, 12:03:15 »
i found out which ones.  they are super expensive!  and they are not buckling spring but NMB Hi-Tek or also know as "Space Invader"
J
« Reply #5 on: Mon, 08 April 2013, 12:07:46 »
You can get space invaders for not too much, like this one. I didn't spend much time searching so there is likey some for a better price.
