Author Topic: Is there 60% with double Fn, and big BS and Shifts?  (Read 2404 times)
Offline omgFiRE
« on: Mon, 08 April 2013, 08:02:44 »
Hello, everyone.
I haven't convinced myself to try 60% board due to their non-standard mechanical layouts. Is there 60% board with mechanical layout, that I would like?:
- Ability to activate Fn by both hands, and I still need Ctrl, Win, Alt at the left side of the lowest row. This means 4 buttons on the left of spacebar.
- Relatively big BackSpace, left Shift, right Shift (at least 1.5x width).
- Presence of Space button under `N' `M' buttons, because my space bar shines at this position  :)
Preferably:
- Alpha-numeric buttons at their standard positions.
- Left mod keys (Tab, CapsLock, Shift, Ctrl, Win, Alt) at their standard positions.
- Left side of right Shift at standard position, but length of right Shift could be reduced (but should be at least 1.5x).
- Alt Gr should be somewhere at right side of the lowest row, but I don't care of its exact position.
- I don't care of right Win, right Ctrl, Menu keys. Neither of theirs positions or presence.
I attached two of many layouts, which satisfy mentioned wishes.
Thanks.
« Last Edit: Mon, 08 April 2013, 08:33:31 by omgFiRE »
White Filco Ninja Majestouch-2 Tenkeyless FKBN87M/EFW2 (Cherry MX Brown), CM Storm QuickFire Rapid SGK-4000-GKCL1-US (Cherry MX Blue)
Re: Is there 60% with double Fn, and big BS and Shifts?
« Reply #1 on: Mon, 08 April 2013, 08:50:52 »
There is no 60% keyboard I am aware of that has 4 keys on the left of the spacebar.
metalliqaz's Epsilon 75% board does, though...
http://geekhack.org/index.php?topic=41390.0
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #2 on: Mon, 08 April 2013, 09:37:21 »
New Filco has all but the big BS key:
Here is the thread:  http://geekhack.org/index.php?topic=40018.0
 - Ron | samwisekoi
Offline tricheboars
  • Keyboards are Important!
« Reply #3 on: Mon, 08 April 2013, 10:36:37 »
GH60
Offline justin.wu
  • * Commercial Vendor
  • Less is more
    • TEX
« Reply #4 on: Mon, 08 April 2013, 11:18:55 »
Hi,,you can check TEX keyboard "beetle" (TKB-600)
that's almost layout you want , but just a little different !
if you still have question , come our fans club , http://www.facebook.com/pages/TEX-Electronics-Co-Ltd/472792412756463
you can ask any question in this post or in our fans club !!
cheers !!
Hello, everyone.
Preferably:
Thanks.
make different
« Reply #5 on: Mon, 08 April 2013, 11:35:07 »
Hey, look at that. Only the right shift doesn't meet your criteria, but everything else is there.
Turns out you wanted a Tex Beetle. (Justin, everyone will call this a "Bug," just like the VW car.)
Offline justin.wu
  • Less is more
    • TEX
« Reply #6 on: Mon, 08 April 2013, 11:40:26 »
Ha !! bug is cool !! but why we want call this keyboard "beetle"
because beetle has a hard shell and colorful , red / blue / gray / black / gold ....etc
than's just like our keyboard , CNC top frame ...hard and colorful
just like that
« Last Edit: Mon, 08 April 2013, 11:44:34 by justin.wu »
make different
Offline omgFiRE
« Reply #7 on: Tue, 09 April 2013, 04:40:02 »
Thanks, but I don't think I need Fn at all on 75%, only on 60%  :)
Let's check:
BackSpace at least 1.5x - failed
right Shift at least 1.5x - failed
Space button under `N' `M' buttons - partially
Alpha-numeric buttons at their standard positions - failed ("ZXC" row is shifted by 0.25x to the left)
Left mod keys (Ctrl, Win, Alt) at their standard positions. - failed (Ctrl is freakish big)
"I don't care of right Win, right Ctrl, Menu keys. Neither of theirs positions or presence." - passed  :)
GH60
I don't understand you. Does it have 4 keys on the left of spacebar? Do you mean using spacebar as Fn (for example, space+7->F7)?
cheers !!
Hi!
That's the best layout to my taste, which I have seen so far. I hope your project become successful.
I don't have experience with shifted "ZXC" row. How does it affect touch typing, in case of multiple keyboards in use with slightly different "ZXC" row position?
Thank you.
Turns out I do.  :)
Too bad, that double Fn are incompatible with big right Shift.  :(
« Last Edit: Tue, 09 April 2013, 13:18:55 by omgFiRE »
