Author Topic: Small keyboard  (Read 5475 times)
Offline Kamland
Small keyboard
« on: Mon, 08 April 2013, 16:46:51 »
Anyone here that knows if I can get a keyboard about this size with the function keys where they are in nordic verison?
Re: Small keyboard
« Reply #1 on: Mon, 08 April 2013, 17:05:39 »
you might want to try and find a kbt pure pro in nordic.  May have some luck there, but most 75% layouts like that mini are ansi.
Offline Kamland
Re: Small keyboard
« Reply #2 on: Mon, 08 April 2013, 17:13:31 »
I only found French and Spanish ones, but are they keys programmed to be like æøå, or is that changeable on a Spanish/French keyboard?
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Small keyboard
« Reply #3 on: Mon, 08 April 2013, 17:16:20 »
Legends on the keys have zero to do with comes out when typing. Keymaps are all handled in the operating system. There should be nordic version of 60% soon, I gave you link for Ducky Nordics stuff in your other thread.
Only 75% I can think of that is MX ISO is Quantel, but they are a terminal board so would require some heavy modding for controller replacement to make it working on a PC.
Offline justin.wu
  • * Commercial Vendor
  • Less is more
    • TEX
Re: Small keyboard
« Reply #4 on: Mon, 08 April 2013, 19:22:22 »
Hi ! that keyboard you want find called "choc mini keyboard" , but I don't know this one have nordic layout ,
if you want find small size keyboard , there have many choice
1. filco http://www.diatec.co.jp/en/MINILAUK/ , but I think that only have UK layout ,
2. KBT pure , that maybe have nordic , but I don't have picture , because they don't have official web site
3. KBC poker 2 (maybe will have nordic)
4. TEX beetle , that is the keyboard that I made , you can check this layout ,
and keyboard outlook picture http://www.flickr.com/photos/jewu8210/sets/72157632574538186/with/8556317769/
if you have any question , come to our facebook , http://www.facebook.com/pages/TEX-Electronics-Co-Ltd/472792412756463
or mail to me  justin@tex-design.com.tw
make different
Offline Kamland
Re: Small keyboard
« Reply #5 on: Tue, 09 April 2013, 05:43:29 »
I want the function keys to be directly over 12345 and not the usual spacing and pushed to the right. I want it like its on the pic.
Re: Small keyboard
« Reply #6 on: Tue, 09 April 2013, 09:02:45 »
Then sorry to tell you, you will have to get ANSI then as there is currently no such thing in ISO.
