Author Topic: Flashget G600 on www.v-dxd.com is this a legit site?  (Read 3086 times)
Offline ITzNybble
  • Formerly curro123083
  • Nibble or Nybble either way it sounds delicious!
« on: Tue, 09 April 2013, 11:49:12 »
Hey all,
I am looking at possibly buying the Flashget G600 and then getting some custom key caps for it but ran across this website. Has anyone used this website or know if it is legitimate to order from? I really like that the keyboard has a metal case and the Corsair look. If I do get this I will definitely write up a review as I have not seen one around here.
Thanks for the help.
http://www.v-dxd.com/flashget-g600-belly-the-spirit-full-87-metal-keyboard-p-1496.html
WASD V1 Custom - MX Blue
Custom Miami QFR - MX Green
Handwired Redox-Manuform - Box Pink/Box Navy
KBD67 MKII PolyCarbonate - Gateron CJ
Offline ITzNybble
Re: Flashget G600 on www.v-dxd.com is this a legit site?
« Reply #1 on: Tue, 09 April 2013, 11:51:59 »
Also if anyone knows what type of key caps would work on the G600 that would be great to know. I am guessing OEM.
Offline tricheboars
  • Keyboards are Important!
« Reply #2 on: Tue, 09 April 2013, 12:26:00 »
pretty cool board. it reminds me of a neo 87 or a poker with a  low profile vortex case (what i am typing on right now).  you can probably put any profile caps you want on it. dsa profile caps would look really neat as it would accent the gap between the plate and the keycaps bottoms.
Offline ITzNybble
« Reply #3 on: Tue, 09 April 2013, 12:45:16 »
ooooo....dsa caps would look nice :).
Offline herbyscrub
« Reply #4 on: Thu, 25 April 2013, 00:38:59 »
Did you end up trying the website out?  I just stumbled on this myself.  There's a $99 eBay auction, but this is way cheaper.
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #5 on: Thu, 25 April 2013, 01:12:29 »
IF IT SEEMS TOO GOOD TO BE TRUE, THEN IT DEFINITELY IS.
NO reviews.
NOT on Reseller Ratings.
FAKE address.
FAKE phone number.
You're an IDIOT if you give them your credit card.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline FoxWolf1
  • 154
« Reply #6 on: Thu, 25 April 2013, 10:13:18 »
Even if it is legit, which seems unlikely, it's not actually that good a deal, because the price you see doesn't include shipping. Once you add in shipping, it's not that much less than the ones on eBay, which are the newer "Battle Version"-- which appears to include additional media control functions and an extra whole set of keycaps.
Offline ITzNybble
« Reply #7 on: Thu, 25 April 2013, 10:21:53 »
Sorry about not posting on this for a while. I ended up not using this website or buying the board at all yet. But the website just seemed sketchy to me so I said neigh.
