Author Topic: Keyboard identification  (Read 1885 times)
Offline mangobaobab
« on: Tue, 09 April 2013, 13:42:07 »
http://static.limundoslike.com/originalslika-22941181.jpg
The seller doesn't know the brand so he sells it as uknown, and he doesn't have AT port so he is selling it as untested.
Could you please tell me what is the brand of this keyboard?
Offline Tarzan
  • formerly known as Greystoke
Re: Keyboard identification
« Reply #1 on: Tue, 09 April 2013, 13:49:36 »
No idea.  Nice German layout, though!   ;D
I love those number pad modifiers!
Offline mangobaobab
« Reply #2 on: Tue, 09 April 2013, 13:53:06 »
I have a Model M from 1991 with german layout, love it :)
I'm always thinking, that whenever I type command to bash shell it says: Jawohl, Herr Kommadant!
Offline mangobaobab
« Reply #3 on: Fri, 12 April 2013, 04:24:30 »
More pictures:
http://static.limundoslike.com/originalslika-23234629.jpg
http://static.limundoslike.com/originalslika-23234633.jpg
Anyone had experiences with these type of switch or keyboard? Any good?
Offline davkol
  •  Post Editing Timeout
« Reply #4 on: Fri, 12 April 2013, 05:35:04 »
I guess it's BTC foam/foil. If you search a bit, you may find some relevant info. Keycaps should be compatible with Cherry MX.
Offline laffindude
« Reply #5 on: Fri, 12 April 2013, 05:35:54 »
I thought it is a rubber dome. Never the less, foam and foil feels like junk.
Offline mangobaobab
« Reply #6 on: Fri, 12 April 2013, 07:19:44 »
thanks guys. it's starting price is 1 cent, I don't believe it'll reach more. But if it's a junk I don't need it anyway!
Offline czarek
  • Keep the momentum going!
    • FalbaTech
« Reply #7 on: Fri, 12 April 2013, 10:51:45 »
Rubbish. You won't find anything exciting under this faded and yellowed keycaps. All you can count is dirt, hair and rubber domes.
Offline davkol
« Reply #8 on: Fri, 12 April 2013, 12:05:44 »
I agree those keycaps look horrible, so they wouldn't be useful with another keyboard. However, BTC 5xxx series isn't all that bad. I really like some of their rubber domes.
