Author Topic: retr0brite on non yellowed caps  (Read 3248 times)
Offline tauburn
« on: Wed, 10 April 2013, 13:34:18 »
I was wondering, if i were to take any set of keycaps and use retro brite on them would it change the colour of the plastic?
such as taking a set of black keys and make them into grey.
Offline The_Ed
  • Asperger's... SQUIRREL! I'm Anal Retentive *****!
Re: retr0brite on non yellowed caps
« Reply #1 on: Wed, 10 April 2013, 13:51:46 »
Try it - FOR SCIENCE!
Reaper "frelled" me... Twice... Did he "frell" you too?... *brohug*
I'm camping for a week, and moving twice in a month. I'll get back to you when I can (If I don't then just send me another PM).
R.I.P.ster
Offline tauburn
« Reply #2 on: Wed, 10 April 2013, 13:53:52 »
i probably will once i get my new keycap set, but someone on here must have by now or at least knows what the peroxide solution does and what the outcome would be
Offline pix3l_fodder
« Reply #3 on: Sat, 13 April 2013, 14:39:55 »
im pretty sure it wont work
Offline salmo
    • messmore.org
« Reply #4 on: Sun, 21 April 2013, 09:10:08 »
I'm pretty sure it'll work...ish. You'll need to do it for some excessive times, and the results will likely be uneven.  Basically you'll be intentionally doing a bad retrobrite job.
To get it more even I would recommend not doing the gel, but just using a peroxide/oxyclean solution and agitating periodically to make sure to not have dark spots where things float or touch the container and such.
