Author Topic: Rec'd my Pure 60% today! Pics  (Read 1950 times)
Offline dmreeves
« on: Wed, 10 April 2013, 15:41:12 »
I am newish here to GH and arrived shortly after researching places to buy the noppo choc mini. Thanks to those around here I found a KB that much better suits my tastes, the KBT Pure 60%. Thankfully I didn't have to go far to buy one as Mechanical keyboards.com had them in stock. Anyways I got a black PBT non-LED with cherry MX Red switches. I also picked up some O Rings and will be installing them shortly.
First Impressions:
Lighter than I expected.
Love the reds.
Love PBT vs ABS.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
Re: Rec'd my Pure 60% today! Pics
« Reply #1 on: Wed, 10 April 2013, 16:37:06 »
Really nice board. Congratulations!
Thanks for sharing the pictures too.
Offline dmreeves
« Reply #2 on: Wed, 10 April 2013, 20:21:37 »
Thanks! I love it. Question for you guys, what kind of stabilizer is that under the enter key? And what's the safest way to remove the key cap? I almost pulled one side of it out of the PCB trying to remove the cap :/ Did manage to get it back in place but am a little worriedabout removing the other key caps with stabilizers under them.
Offline Jocelyn
  • 조셀린
« Reply #3 on: Wed, 10 April 2013, 20:24:37 »
No need to be worried, because they are Cherry PCB mount stabilizers and not Costar stabilizers. I usually use a wire puller on one side to get it off one stab, then use something as a wedge on that same side to prevent it from mounting again all while using the wire puller on the other side to remove the cap.
I hope that makes sense :)
Edit - Oh and I use a spudger for the second part, but there are other things you can use.
« Last Edit: Wed, 10 April 2013, 20:28:15 by Jocelyn »
« Reply #4 on: Wed, 10 April 2013, 20:30:46 »
Here's a pic just in case you wanted it. Jocelyn sniped me!
And I just rocked a wirepuller back and forth and pulled hard.
Congrats, I just got my first Pure this weekend as well.
Offline dmreeves
« Reply #5 on: Wed, 10 April 2013, 20:44:48 »
OK cool guys thanks for the tips. I will continue installing orings when I get home from work.
Offline ComradeSniper
  • HHKB Pro
« Reply #6 on: Wed, 10 April 2013, 20:44:54 »
Those MX Whites  :cool:
Offline dmreeves
« Reply #7 on: Thu, 11 April 2013, 02:51:31 »
So after work tonight (I could hardly wait to get home, what a geek I truly am) I rushed upstairs to finish installing the O rings onto my board. Had no trouble getting the other keys with stabilizers off this time as I was more careful and applied pressure evenly to both sides of key. Would have use a keypuller but had no trouble getting the keycaps off of my old steelseries 6gV2 without one so I figured this would be as easy. Loving the quiet muted thump that all the keys make now as opposed to the click clack of them bottoming out. I also think that my WPM has gone up as typing is more efficient when keys don't bottom out.
Found a basic diagram of all the functions on the PURE and thought it might be worthwhile to post here so I don't lose it :)
