Author Topic: Is this 122-key a Model M or a Model F?  (Read 1573 times)
Offline ed_avis
« on: Thu, 11 April 2013, 08:22:52 »
Description says Model M, but stairstepped Alt keys indicate F.  http://www.ebay.co.uk/itm/190816149468
The photo of the label on the back is inconclusive...
Offline esoomenona
  • Gnillort?
Re: Is this 122-key a Model M or a Model F?
« Reply #1 on: Thu, 11 April 2013, 08:24:53 »
Plastic bottom is Model M, correct?
Offline esoomenona
  • Gnillort?
« Reply #2 on: Thu, 11 April 2013, 08:27:21 »
« Reply #3 on: Thu, 11 April 2013, 08:30:06 »
It is an M, but a very early one.
That is an F-style case with plastic back instead of metal.
I have been looking for one of those (cheap) and have seen that picture on ebay before.
- Oliver Willis 2026-08-01
Offline ed_avis
« Reply #4 on: Thu, 11 April 2013, 08:32:51 »
Thanks.  I continue to hunt down a cheap F122 just to nick the spacebar stabilizer from it.
« Reply #5 on: Thu, 11 April 2013, 08:58:11 »
Oh, yes.
I could build another F-122 from the parts I have on hand, if I only had another spacebar.
The spacebar is the same size as the M, but the F wire is considerably thinner.
I do not think that it would be hard to fabricate a more generous tab and epoxy it to the plate to accommodate the M wire. I have considered bending a "Z" shaped piece of wire, such as a 1cm section from a large paper clip. There is little pressure on the tab, it would not have to be overly strong (the stock press-fit plastic ones certainly aren't).
Wondering about a compatible spacebar is another reason that I have wanted to get my hands on one of those very early M-122s.
