Author Topic: Where to get BLANK PBT wasd keycaps  (Read 2338 times)
Offline rec0ver
« on: Fri, 12 April 2013, 22:03:55 »
I was trying so hard to find an Blank PBT wasd set for my filco TKL.
After spending over $60 on other nice keycaps(mostly for function row) while im doing the research, i still couldn't find what i want.
So im here to asking for your help.
I appreciate if anyone can give me a link or PM me.
Color doesn't really matter, but orange or red would be my first choice.
Thank you in advance.
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Where to get BLANK PBT wasd keycaps
« Reply #1 on: Sat, 13 April 2013, 09:35:32 »
http://keycapsdirect.com/inventorypdfs/DCSPBTInventory.pdf
You would need 1x Row 2 and 3 qty. 1x row 3.
Then once you find color you like, go to this page to enter the code to place in shopping cart.
These will be slightly lower than stock Filco keycap.
Offline rec0ver
« Reply #2 on: Sat, 13 April 2013, 20:56:52 »
Thanks for replying, ill try :D
