Author Topic: What type of switches are ?  (Read 2355 times)
Offline Retrete
« on: Sat, 13 April 2013, 13:13:20 »
Hi guys! As the title says , what type of switches are these ones?
Offline davkol
  •  Post Editing Timeout
Re: What type of switches are ?
« Reply #1 on: Sat, 13 April 2013, 13:16:06 »
Probably BTC foam/foil.
Offline rarar
  • moist booty seepage
« Reply #2 on: Sat, 13 April 2013, 14:30:32 »
plunger and spring over rubber dome
Ỏ̷͖͈̞̩͎̻̫̫̜͉̠̫͕̭̭̫̫̹̗̹͈̼̠̖͍͚̥͈̮̼͕̠̤̯̻̥̬̗̼̳̤̳̬̪̹͚̞̼̠͕̼̠̦͚̫͔̯̹͉͉̘͎͕̼̣̝͙̱̟̹̩̟̳̦̭͉̮̖̭̣̣̞̙̗̜̺̭̻̥͚͙̝̦̲̱͉͖͉̰̦͎̫̣̼͎͍̠̮͓̹̹͉̤̰̗̙͕͇͔̱͕̭͈̳̗̭͔̘̖̺̮̜̠͖̘͓̳͕̟̠̱̫̤͓͔̘̰̲͙͍͇̙͎̣̼̗̖͙̯͉̠̟͈͍͕̪͓̝̩̦̖̹̼̠̘̮͚̟͉̺̜͍͓̯̳̱̻͕̣̳͉̻̭̭̱͍̪̩̭̺͕̺̼̥̪͖̦̟͎̻̰_Ỏ̷͖͈̞̩͎̻̫̫̜͉̠̫͕̭̭̫̫̹̗̹͈̼̠̖͍͚̥͈̮̼͕̠̤̯̻̥̬̗̼̳̤̳̬̪̹͚̞̼̠͕̼̠̦͚̫͔̯̹͉͉̘͎͕̼̣̝͙̱̟̹̩̟̳̦̭͉̮̖̭̣̣̞̙̗̜̺̭̻̥͚͙̝̦̲̱͉͖͉̰̦͎̫̣̼͎͍̠̮͓̹̹͉̤̰̗̙͕͇͔̱͕̭͈̳̗̭͔̘̖̺̮̜̠͖̘͓̳͕̟̠̱̫̤͓͔̘̰̲͙͍͇̙͎̣̼̗̖͙̯͉̠̟͈͍͕̪͓̝̩̦̖̹̼̠̘̮͚̟͉̺̜͍͓̯̳̱̻͕̣̳͉̻̭̭̱͍̪̩̭̺͕̺̼̥̪͖̦̟͎̻̰ ด้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็_ด้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็
Offline davkol
« Reply #3 on: Sat, 13 April 2013, 14:43:50 »
Isn't the keyboard BTC 5339?
Offline babyhands
« Reply #4 on: Sat, 13 April 2013, 15:03:23 »
im curious as to how those feel?
Offline Retrete
« Reply #5 on: Sat, 13 April 2013, 15:08:38 »
Mmm not exactly, its a  BTC-5349 ,
 and the chinese post about it ;
http://www.pcwaishe.cn/thread-13859-1-1.html
« Reply #6 on: Sat, 13 April 2013, 15:47:36 »
No, you can clearly see the foam and the foil in the pictures. It is foam-and-foil.
BTC have made plunger over rubber dome keyboards, though, that have some similarities with these.
