Author Topic: Two-tone laser-etched thick PBT availability, and information  (Read 9279 times)
Offline templai
Will this set fit a Filco MJ2 without any major problems? I'm worried about the stepped caps lock which is usually off-center. Are they regular or thick PBT?
Also, I'm assuming the extra key off of 105 included is the centered stem caps lock.
« Last Edit: Sat, 20 April 2013, 14:08:41 by templai »
Offline bazemk1979
Re: Two-tone laser-etched thick PBT availability, and information
« Reply #1 on: Sun, 14 April 2013, 21:59:44 »
when they are 105 keys  the set comes with off center stepped capslock for cherry boards or the custom Korean boards and the regular center stemmed not stepped capslock for todays market boards, you need to contact imsto more on the thickness info and make sure about the caps lock.
Offline templai
« Reply #2 on: Mon, 15 April 2013, 15:22:54 »
I see, thanks.
