Author Topic: IBM M5-1 trackball  (Read 4314 times)
Offline tipo33
  • "Ski"
IBM M5-1 trackball
« on: Mon, 15 April 2013, 00:18:39 »
The M5-1 Is a Model M with a trackball above the arrow cluster.  Has anyone tried one?  Are they actually usable?  Is it worth tracking one down?  Thank you.
KM4COL    R.I.P.  SmallFry
Offline bazemk1979
Re: IBM M5-1 trackball
« Reply #1 on: Mon, 15 April 2013, 01:01:15 »
Offline tipo33
  • "Ski"
« Reply #2 on: Mon, 15 April 2013, 03:18:02 »
I don't like the placemant.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #3 on: Mon, 15 April 2013, 08:04:31 »
M5-1 has the trackball above the arrow keys, M5-2 has it above the numpad.
I have previously owned an M5-2 and find the placement quite usable, but it's a very low resolution tracking device. I have not used the M5-1 but I'm inclined to say it's probably less usable than the M5-2 because you can't really cup your hand around it.
kishy.ca
Offline SmallFry
« Reply #4 on: Mon, 15 April 2013, 08:08:14 »
A wild Kishy appears!
Offline tipo33
  • "Ski"
« Reply #5 on: Mon, 15 April 2013, 09:39:35 »
I saw both, I think I would like the M5-1 more because I usualy rest my fingers above the arrow cluster anyways, and I could operate it with my index finger.  I was curious to it's sensitivity, and weather or not it is even worth it to try to get it to work on a modern computer.  I figure even with a low DPI trackball you could play with the sensitivity settings in the OS and get it to work.
