Author Topic: Recommendations on a quiet 60% board  (Read 1768 times)
Offline hoonose
« on: Mon, 15 April 2013, 00:45:43 »
I got my first mech board a few months ago (Das with Cherry blues) and I love it. However, it's far too loud to use at the office, and a bit awkward to travel with (my friends told me to just use my laptop keyboard when travelling - I figure you guys would sympathize more :P).
Anyway, my desired attributes are:
  • Quieter switches. I've tried Cherry Blues and Browns (tried out a Das with browns). I think Blues would be too loud, but Browns seem OK.
  • 60% design. I'm looking for something that's small and easy to travel with
  • I'd like arrow keys rather than right ctrl,alt,shift, since I never use those keys
  • this is a bit of a strange one - I'd like the \ key to be in the "regular" position (above enter, below backspace). Alternatively, a \ which is easier to reach than the current location. This one probably isn't a dealbreaker, since remapping is easy. I use LaTeX for typesetting, which relies heavily on \.  I found an old keyboard at the office with space invader switches which is OK (albeit pretty dirty, haven't got a chance to clean it yet), but the \  is next to the += key, which is a bit weird to get used to.
Any recommendations would be much appreciated.
Offline omgFiRE
Re: Recommendations on a quiet 60% board
« Reply #1 on: Mon, 15 April 2013, 01:19:43 »
There is some people who like some good scissor keyboards (like some thinkpad do have). You could also try Cherry ML for cheap
http://www.ebay.com/itm/Cherry-Slimline-Keyboard-83-Keys-USBPS2-Grey-G844100-/380553840843
In case of Cherry look at non-clicky switches: http://deskthority.net/wiki/Cherry_MX
You could also use dampener (o-ring) to muffle bottom out.
If you like Blues, I think it would be reasonable to ask your colleagues first, than limit yourself with probably non-existent limitation. Blues and Browns not only sound different, they also feel different.
I think any 60% will fit. Some keyboards have option to switch right shift to arrow, like poker or pure http://mechanicalkeyboards.com/search.php?keyword=pure&in_stock=on
Some keyboards have dedicated arrows: TEX Beetle, Filco MINILA, Pure Pro (Poker 2), Leopold FC660M, Matias Mini Quiet Pro.
« Last Edit: Mon, 15 April 2013, 01:46:30 by omgFiRE »
White Filco Ninja Majestouch-2 Tenkeyless FKBN87M/EFW2 (Cherry MX Brown), CM Storm QuickFire Rapid SGK-4000-GKCL1-US (Cherry MX Blue)
Offline TAdams
  • Professional Lurker
« Reply #2 on: Mon, 15 April 2013, 01:32:00 »
I agree with omgfire. For cherry mx switches, you could use o-rings to minimize noise if you tend to bottom out.
i want to unsee that - eyebleach plz!
Offline davkol
  •  Post Editing Timeout
« Reply #3 on: Mon, 15 April 2013, 02:11:53 »
Looks like the TEX keyboard might work for you (note that it has non-standard staggering and right shift.
I recommend to check Cherry MX Clear (or ergo clears), they're quieter and much more tactile than browns IMHO.
