Author Topic: Looking for a Space Bar. Quickfire TK.  (Read 7040 times)
Offline ParrotAttack
« on: Mon, 15 April 2013, 04:45:24 »
Hello Geek Hack,
I have a quickfire tk, and am wondering if it's possible to get a space bar for these? I believe the sizing is 6.5 but don't quote me on that please  ;D
Parrot.
« Last Edit: Mon, 15 April 2013, 07:16:52 by ParrotAttack »
Offline inteli722
Re: Looking for a Space Bar. Quickfire TK.
« Reply #1 on: Mon, 15 April 2013, 07:42:10 »
I can confirm that it appears to be 6.5x,  based on doing a few quick calculations.
Well, I'm afraid that I don't know about any 6.5x spacebars. Only 6x, 6.25x and 7x. If you need a scapegoat, go blame CoolerMaster's OEM that makes this one.
Waiting for: Phantom Plate
« Reply #2 on: Mon, 15 April 2013, 07:54:22 »
Firstly, thanks for the clarification. Secondly, I will blame the OEM :D
I guess my options are too leave the space bar as is if I replace the keys then.
Parrot.
Offline inteli722
« Reply #3 on: Mon, 15 April 2013, 07:57:12 »
You'll also have to buy some extra stuff.
Bottom row looks like:
1.5x, 1x, 1.25x, 6.5x, 1.25x, 1x, 1x, 1.5x,
You have to buy at least a tsangan and mods if you get custom caps.
« Reply #4 on: Mon, 15 April 2013, 08:37:47 »
Yep, 6.5x is correct. In regards to the modifier keys, thankfully the group buy's on here seem to be doing more and more of alternate keys for the bottom row :)
Just curious if anyone had any luck using a 6.25x or a 6.0x and having slight gaps at the side (I know the stabilisers would need to be in the same place, but its a possibility!)
And i'm also english, so have the ISO layout one, even more additions required!
Owh well, it's a nice keyboard.
Parrot.
« Last Edit: Mon, 15 April 2013, 10:18:07 by ParrotAttack »
Offline reziak
  • Topre/60% Enthusiast
« Reply #5 on: Wed, 31 July 2013, 13:10:16 »
I'm also looking for a spacebar for a Quickfire TK...Preferably white/gray/beige/aluminum. Anyone have any luck?
HHKB Pro 2 | FC660C | HHKB Pro 2 Type-S
Offline COFFFEEEE
« Reply #6 on: Wed, 31 July 2013, 13:32:02 »
Exactly why i am not using Max keyboard now.
hard to find PBT keycaps for the bottom row.
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #7 on: Wed, 31 July 2013, 22:10:49 »
There's literally only like 2 or 3 keyboards that use a 6.5 space, chances of anyone making aftermarket ones is pretty much zero.
