Author Topic: Different sound on Esc key  (Read 3217 times)
Offline exousia7
« on: Mon, 15 April 2013, 11:42:11 »
So I purchased a Ducky 9000G2 with MX blue switches, and when I got it I played around with it and realized the Esc key sounded different from the rest of the other keys.....is this normal?
Offline AuRinBei
Re: Different sound on Esc key
« Reply #1 on: Mon, 15 April 2013, 11:57:36 »
How different? Like a lower or higher pitch? If so, that's normal. Keys make slightly different sounds on the keyboard depending on where they are. Escape key is isolated by itself, so it usually sounds a little different.
87u || Poker 2
Offline exousia7
« Reply #2 on: Mon, 15 April 2013, 11:58:51 »
It's lower pitched clicks compared to other keys
Offline khaangaaroo
« Reply #3 on: Mon, 15 April 2013, 12:37:51 »
Sometimes switches come out of the Cherry factory less clicky. I don't think they're tested for their clickiness, just whether or not they work. There was a run of QFR boards that had a few non-clicky keys and people got butthurt: http://geekhack.org/index.php?topic=40056.0
It's pretty easy to replace the switch. You can even adjust the insides of the switch to make it more clicky if you understand how they work and are good working with small parts.
Offline Rule16
  • R.I.P. SmallFry
« Reply #4 on: Mon, 15 April 2013, 21:32:30 »
If its a pitch difference its acoustics due to the fact that the escape key is in a small isolated hole instead of an island.
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
Offline PointyFox
« Reply #5 on: Mon, 15 April 2013, 21:33:20 »
Does it quack?
Offline bazemk1979
« Reply #6 on: Mon, 15 April 2013, 22:35:05 »
