Author Topic: ID??  (Read 1662 times)
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
ID??
« on: Mon, 15 April 2013, 17:56:55 »
Any idea if this is domes or something else?  It was from a computer my parents  had built for them back around 1997 or so.
Offline SmallFry
Re: ID??
« Reply #1 on: Mon, 15 April 2013, 17:58:13 »
Looks like a dome board. Boards with the rubber buttons up top are typically dome unless you're Corsair and throw that all out the window.
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: ID??
« Reply #2 on: Mon, 15 April 2013, 18:08:01 »
DIT sold the cheapest keyboards possible, bad domes for sure.
Offline Melvang
Re: ID??
« Reply #3 on: Mon, 15 April 2013, 18:24:34 »
Alright thanks guys was curious with the ISO layout and the larger than normal ESC key
Re: ID??
« Reply #4 on: Mon, 15 April 2013, 19:20:58 »
Not ISO, just terrible Asian ANSI.
Offline Melvang
Re: ID??
« Reply #5 on: Mon, 15 April 2013, 21:32:37 »
I am still fairly new to this but what is the difference between this board and a true ISO layout?
Re: ID??
« Reply #6 on: Tue, 16 April 2013, 09:03:32 »
This type of enter requires the \| key to be displaced to some odd location by shortening the backspace, shift, placing it between alt and ctrl... or something else. ISO has a different shape enter to allow extra key on the home row next to instead of above enter and a short left shift to allow an extra key there
an ISO keyboard, you can see how it differs.
