Author Topic: goldtouch?  (Read 4335 times)
Offline djones
goldtouch?
« on: Thu, 08 May 2008, 11:45:12 »
http://www.keyovation.com/pc-65-2-goldtouch-ergonomic-adjustable-keyboard-white.aspx
anyone ever try one of these? opinions? How do the keys feel?
Offline Eclairz
goldtouch?
« Reply #1 on: Thu, 08 May 2008, 16:48:33 »
http://www.keyovation.com/t-macworld0107.aspx
macworld said the keys were mushy, so probably some type of membrane keyboard but the way the keyboard changes angle seems to be well thought out and easy to do
http://www.youtube.com/watch?v=GUWaXnrjcW0
this vid shows how easy it is to setup which i thought was neat, too bad about key quality though
edit: skip to the end of video as the guy will give a massive lecture before showing you the keyboard
Lenovo ThinkPad TrackPoint Keyboard
RealForce 45g UK 88UB
FILCO Majestouch TenKeyPad
Offline JohnnyBoy
goldtouch?
« Reply #2 on: Thu, 08 May 2008, 18:23:17 »
I don't know if this is any use to you djones, but here's an eBay seller that'll ship a black Goldtouch to anywhere in the world...
http://cgi.ebay.co.uk/Goldtouch-GTU-0077-BLACK-Ergonomic-Split-Keyboard-NEW_W0QQitemZ140231265292QQihZ004
Offline IBI
goldtouch?
« Reply #3 on: Fri, 09 May 2008, 07:55:48 »
One came up on ebayUK a couple of months ago for about £25 but when I looked around there were several people who's had problems with keys sticking.
Owned: Raptor-Gaming K1 (linear MX)(Broken), IBM Model M UK, Dell AT102W, Left-handed keyboard with Type 1 Simplified Alps.
Offline puntium
    • http://keyboards.kendeeter.com
goldtouch?
« Reply #4 on: Fri, 09 May 2008, 22:06:39 »
Yep, its standard membrane switches. On the soft side. I don't like them because they don't have any wrist supports. They're good for people who are really anal about keeping their wrists in the air while typing.
FILCO FKBN87M/EB / Microsoft Natural Elite / HHKB2 Pro
Keyboards blog | Keyboard Reviews (old blog)
Offline JohnnyBoy
goldtouch?
« Reply #5 on: Sun, 11 May 2008, 10:28:51 »
Quote from: puntium;4558
I'm with you there, Puntium. I've jacked up the nearest edge of my Logitech ergo k/b so that it's easier to rest my wrists on the wrist support WHILE I type!:D
