Author Topic: PROBLEM SOLVED  (Read 3079 times)
Offline rarar
  • moist booty seepage
PROBLEM SOLVED
« on: Tue, 16 April 2013, 20:56:46 »
LOCKED: PROBLEM SOLV'D
« Last Edit: Tue, 16 April 2013, 21:10:44 by rarar »
Ỏ̷͖͈̞̩͎̻̫̫̜͉̠̫͕̭̭̫̫̹̗̹͈̼̠̖͍͚̥͈̮̼͕̠̤̯̻̥̬̗̼̳̤̳̬̪̹͚̞̼̠͕̼̠̦͚̫͔̯̹͉͉̘͎͕̼̣̝͙̱̟̹̩̟̳̦̭͉̮̖̭̣̣̞̙̗̜̺̭̻̥͚͙̝̦̲̱͉͖͉̰̦͎̫̣̼͎͍̠̮͓̹̹͉̤̰̗̙͕͇͔̱͕̭͈̳̗̭͔̘̖̺̮̜̠͖̘͓̳͕̟̠̱̫̤͓͔̘̰̲͙͍͇̙͎̣̼̗̖͙̯͉̠̟͈͍͕̪͓̝̩̦̖̹̼̠̘̮͚̟͉̺̜͍͓̯̳̱̻͕̣̳͉̻̭̭̱͍̪̩̭̺͕̺̼̥̪͖̦̟͎̻̰_Ỏ̷͖͈̞̩͎̻̫̫̜͉̠̫͕̭̭̫̫̹̗̹͈̼̠̖͍͚̥͈̮̼͕̠̤̯̻̥̬̗̼̳̤̳̬̪̹͚̞̼̠͕̼̠̦͚̫͔̯̹͉͉̘͎͕̼̣̝͙̱̟̹̩̟̳̦̭͉̮̖̭̣̣̞̙̗̜̺̭̻̥͚͙̝̦̲̱͉͖͉̰̦͎̫̣̼͎͍̠̮͓̹̹͉̤̰̗̙͕͇͔̱͕̭͈̳̗̭͔̘̖̺̮̜̠͖̘͓̳͕̟̠̱̫̤͓͔̘̰̲͙͍͇̙͎̣̼̗̖͙̯͉̠̟͈͍͕̪͓̝̩̦̖̹̼̠̘̮͚̟͉̺̜͍͓̯̳̱̻͕̣̳͉̻̭̭̱͍̪̩̭̺͕̺̼̥̪͖̦̟͎̻̰ ด้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็_ด้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็้้้้้้้้็็็็็้้้้้็็็็็
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Shipping
« Reply #1 on: Tue, 16 April 2013, 20:57:58 »
LOL, what? It would be like $14 tops with first class.
Offline rarar
Re: Shipping
« Reply #2 on: Tue, 16 April 2013, 20:58:21 »
Deargod, their website is retarded T_T
Thanks for the help :)
Re: Shipping
« Reply #3 on: Tue, 16 April 2013, 21:00:46 »
Hehehe. Yes it sure is. They try to sucker to spend much more on priority and they make you drag your asss all the way to post office too to send first class. It's such a dirty scam.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
Re: Shipping
« Reply #4 on: Tue, 16 April 2013, 21:01:09 »
That shouldn't be more than $26ish going flat rate priority even.  That sounds like the GXP or Express mail price.
Offline rarar
Re: Shipping
« Reply #5 on: Tue, 16 April 2013, 21:02:03 »
how much would it be for a box, 9.5 long, 6.25 wide, and 4.5 tall with those 33 keycaps, and bubble wrap cost to send? firstclass would be nice, but cheaper would be ok
Offline tjcaustin
  • King Klaxon
    • Buy stuff
Re: Shipping
« Reply #6 on: Tue, 16 April 2013, 21:04:41 »
There isn't anything cheaper than first class.
Also, in full defense, if you click the priority and first class options on "quote me some postage", it shows priority being $24.96 and first class being $12.15.
Re: Shipping
« Reply #7 on: Tue, 16 April 2013, 21:06:45 »
I assumed sturdy box packaging on my first estimate. It should be really close.
There used to be cheaper for international, parcel by sea and it was like almost same as domestic rates but those dirty crooks took it away long time ago.
Offline rarar
Re: Shipping
« Reply #8 on: Tue, 16 April 2013, 21:07:24 »
did you change the country option to singapore though? i go to the postage calculator page, and type in a weight for package. How much would 33 PBT keys weigh?
Re: Shipping
« Reply #9 on: Tue, 16 April 2013, 21:08:04 »
The US Post Office website has got to be the worst and most user-un-friendly that I have ever seen.
Pack the keys well and send them in an envelope. It won't be too bad.
- Franklin Roosevelt 1933
Offline rarar
Re: Shipping
« Reply #10 on: Tue, 16 April 2013, 21:09:01 »
GODDAMNIT I WAS LOOKING AT GXC!!!! T_T_T_T_T This damn piece of **** has made me lose at least a few sells......
Offline tjcaustin
  • King Klaxon
    • Buy stuff
Re: Shipping
« Reply #11 on: Tue, 16 April 2013, 21:09:22 »
I did.  And I would expect no more than a pound.  I put in half a pound.  Flat rate priority is good for up to 4 lbs for small I think.  You may be risking parcel instead of first class if you go that way, which is just a stupid halfway between first and priority for abnormal packages.
See?  Told you.
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
Re: PROBLEM SOLVED
« Reply #12 on: Tue, 16 April 2013, 23:41:51 »
Please do not do this.
If you want to lock your thread, that's fine.  But don't edit out the OP and the subject.  Now this potentially useful reference thread is headless and confusing.
