Author Topic: Where to get transparent keycaps?  (Read 11797 times)
Offline jello
    • Hydro Shop
« on: Thu, 18 April 2013, 13:19:14 »
I currently own a couple of backlit mechanical keyboards. I'm now getting tired of the old keys and looking forward to change them with some keys which are transparent and allow the light to pass through.
Which would you guys suggest for good quality and meet the requirement above.
I can go probably around 50 to 70 bucks.
P/S: I have the Razer BWU and CM Storm Trigger.
CM Storm Quickfire TK
CM Storm Quickfire Pro
Razer Blackwidow 2013
Offline Jagriff
« Last Edit: Thu, 18 April 2013, 13:33:34 by Jagriff »
Offline jello
    • Hydro Shop
Re: Where to get transparent keycaps?
« Reply #2 on: Sat, 27 April 2013, 13:09:23 »
Thanks man, that helped alot.
