Author Topic: Problem with Apple Extended Keyboard II  (Read 3098 times)
Offline Jaydoublem
« on: Fri, 16 May 2008, 12:34:24 »
I use an Apple Extended II with an iMate on a Powerbook G4.
The problem is that a lot of times when I type a W, it comes up twice. This is extremely annoying when I close tabs or windows in a program because it closes 2 of them. When I reconnect the cable of the keyboard, it usually solves the problem for a little bit.
Do you think that this is a software/hardware/iMate problem? How can I resolve this? Thanks
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
« Reply #1 on: Sat, 17 May 2008, 00:14:37 »
I'd blame the iMate. I have one and have used it a lot in the last couple months and I actually have to disconnect the keyboard in order to shut down my MacBook. Thinking of picking up a new Alps keyboard because of it.
Offline Jaydoublem
« Reply #2 on: Sat, 17 May 2008, 00:35:28 »
alright thanks for the reply
Offline Jaydoublem
« Reply #3 on: Sat, 17 May 2008, 09:58:43 »
On the "thetalkshow" the guy says that he replaced his 14 year old Extended Keyboard II after he started getting duplicate E's. So that seems like the same problem that I am having.
