Author Topic: Anyway websites that show how to change a spring on model m?  (Read 1171 times)
Offline uphillcastle
« on: Sat, 20 April 2013, 14:22:57 »
Just got my ibm model from ebay and it is indeed fantastic. Liking the feel possibly more than my filco... however the delete key just doesn't feel as crisp as the other keys and I'm guessing that it might be a spring thing, so anyone know of any guides in the swapping of springs? Thanks
Offline bazemk1979
Re: Anyway websites that show how to change a spring on model m?
« Reply #1 on: Sat, 20 April 2013, 14:30:04 »
you need a new spring, remove old spring and insert new spring by pushing down and turning it either clockwise or counter clockwise, you got to sort of test that out on your own.
« Reply #2 on: Sat, 20 April 2013, 14:36:51 »
okay i'll give it a shot, thanks.
Offline nsrexler
« Reply #3 on: Sat, 20 April 2013, 15:07:33 »
Talk to Unicomp at http://pckeyboard.com/, they may be able to help you out and possibly even service it for you.
