Author Topic: EBAY: Deck Legend Frost (MX Clear) 8PM CST 4/22  (Read 6721 times)
Offline dante
Offline csloan1218
  • Technomancer
Re: EBAY: Deck Legend Frost (MX Clear) 8PM CST 4/22
« Reply #1 on: Mon, 22 April 2013, 12:45:12 »
What kind of keys are these that the legends will never rub off?
Ducky DK9008 Shine II Blue LED Backlit (Red Cherry MX)
Leopold Linear Touch FC500RR/AB (Red Cherry MX)
Offline Latin00032
« Reply #2 on: Mon, 22 April 2013, 13:16:47 »
In the description, it looks like it is clear switches.
It looks like it says it at the bottom.
Offline csloan1218
  • Technomancer
« Reply #3 on: Mon, 22 April 2013, 13:23:26 »
I looked again and unless I missed it, there's nothing about the keys except a claim they never wear.
I looked at decks website and there is no info there either about the key material or process, just the same emphatic claim.
I'm just curious.
Offline elttaboi
« Reply #4 on: Mon, 22 April 2013, 13:23:36 »
Aren't these built like tanks?
« Reply #5 on: Mon, 22 April 2013, 13:23:40 »
they are double shot
« Last Edit: Mon, 22 April 2013, 13:51:40 by Binge »
Offline csloan1218
  • Technomancer
« Reply #6 on: Mon, 22 April 2013, 13:34:14 »
I was looking and this is what I turned up on their website
12. Will the letters on the keycaps wear off eventually?
NEVER! Characters can't chip off the key caps or wear down because we use a sublimated negative printing process which drives the ink into the plastic keycaps at 525°F. This means permanent printing from the inside out, not just on the top, and gives the letters a permanent place inside the plastic.
This looks like something other than doubleshot.
I like the caps tho, anything wear resistant on an illuminated board would be a nice addition.
« Reply #7 on: Mon, 22 April 2013, 13:50:18 »
I guess it depends on the version of the keyboard?  This has gotten me confused >.< Sort of not liking these caps.
Maybe there's a dye sub as well?
« Last Edit: Mon, 22 April 2013, 13:52:28 by Binge »
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #8 on: Mon, 22 April 2013, 13:50:23 »
They are not doubleshot they are a 2 piece keycap with black dyesub on a semi opaque white PBT top with a black 'skirt'. They never used doubleshots on these, they always had these type of 2 piece dyesub. Perhaps the caps being 2 piece was confused with doubleshot.
« Last Edit: Mon, 22 April 2013, 13:52:03 by IvanIvanovich »
Offline elttaboi
« Reply #9 on: Mon, 22 April 2013, 15:25:47 »
Well that's an interesting way to make backlit keycaps.
Offline bazemk1979
« Reply #10 on: Mon, 22 April 2013, 17:14:26 »
they wont wear off, at least not in your life time lol
Offline jabar
« Reply #11 on: Mon, 22 April 2013, 19:22:47 »
It's patented too which is why they aren't seen on any keyboards other than TG3s (Deck). However the edge between the two shots seems visible on every keycap (I haven't use one personally so I wouldn't know if that is noticeable).
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline csloan1218
  • Technomancer
« Reply #12 on: Mon, 22 April 2013, 19:24:53 »
I would like to try out a set of these caps, but there is some tremendous bleed on the back lighting on these keyboards.
Offline jabar
« Reply #13 on: Mon, 22 April 2013, 19:28:52 »
Buy a TG3 BL82 instead for $50 + shipping. Not a full keyboard set, and weird for a sub TKL layout but at least it doesn't have the silly Deck font.
http://www.globaltekoutlet.com/TG3-Electronics-BL82-Series-Backlit-Keyboard-p/bl82.htm
Phantom 7bit
Offline Tarzan
  • formerly known as Greystoke
« Reply #14 on: Mon, 22 April 2013, 20:00:58 »
Oh, it's noticeable all right.   ;D
I just got my first TG3 today, from the pictures it almost looked like the keycaps had labels on each one.  Up close you can see the line between the two cap materials, but there's no apparent raised seam.  The inner portion of each keycap is a different texture, but they feel great, kind of like a less "gritty" PBT.
« Reply #15 on: Mon, 22 April 2013, 20:06:52 »
I kind of like the font, but the keyboard itself is just plain butt-ugly, and the way they handled the secondary legends is totally clumsy.
- Oliver Willis 2026-08-01
Offline Tarzan
« Reply #16 on: Mon, 22 April 2013, 20:17:01 »
Actually, I like the way TG3/Deck does the secondary labels.  I got a CM Storm Trigger board as my first back-lit mechanical, and it was a complete PITA to type on in dim light.  Oh, the backlight worked great to tell the "C" key apart from the "X," but all the secondary labels are in the non-backlit portion of the keycaps.   :mad:
Offline jabar
« Reply #17 on: Mon, 22 April 2013, 20:20:35 »
It's not that good of a price considering, but is anyone waiting to snipe this?
Phantom 7bit
Offline csloan1218
  • Technomancer
« Reply #18 on: Mon, 22 April 2013, 20:31:30 »
I'm a big fan of illuminated boards, and especially supposedly "indestructible" ones. But I just put out too much green after discovering mech keyboards recently.
If my wife knew I would be !@#$%^& proper.
Offline dante
« Reply #19 on: Mon, 22 April 2013, 20:49:16 »
15m
« Reply #20 on: Mon, 22 April 2013, 21:21:47 »
There are some more affordable BL82 with clears.
Offline jabar
« Reply #21 on: Mon, 22 April 2013, 21:31:25 »
Wow I never even bothered to look for a new Clear BL82...
I'm aware of the mod that needs to be performed specifically for the MX Clear BL82... is that documented here somewhere? I tried searching in the past.
Phantom 7bit
Offline dante
« Reply #22 on: Mon, 22 April 2013, 21:33:27 »
My only complaint with the Deck 82 / TG3 BL82 is how tall it is.  It caused a bit of wrist/hand pain in my situation.  You definitely want to use something like this with it:  http://www.amazon.com/Mechanical-Keyboards-MacBooks-Notebooks-Neoprene/dp/B004DANDN4/ref=sr_1_15?ie=UTF8&qid=1366684382&sr=8-15&keywords=keyboard+wrist+rest
Offline missalaire
  • Great Finder of Great Finds
« Reply #24 on: Wed, 24 April 2013, 11:18:21 »
Offline Tarzan
« Reply #25 on: Wed, 24 April 2013, 11:34:19 »
http://www.ebay.com/itm/151033472429?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1586.l2649
Now $75 starting bid, and $125 buy it now.
I might be tempted by the Toxic version at that price, but not the Frost.  Does look nice with the clear case option, though.
Offline jabar
Phantom 7bit
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #27 on: Mon, 29 April 2013, 03:28:33 »
nabbed for $75
Dood! Awesome deal! If I didn't already own this Ducky w/ Clears, I totally would've waged a furious bidding war with you on ebay :P
