Author Topic: QFR vs QFR stealth  (Read 1805 times)
Offline phx
QFR vs QFR stealth
« on: Tue, 23 April 2013, 10:09:01 »
is there a difference between the two aside from the cover and the caps?
Offline mR_fRag`
Re: QFR vs QFR stealth
« Reply #1 on: Tue, 23 April 2013, 10:11:45 »
No
Filco MJ2 87 Mx Blue    Filco MJ2 87 Mx Red    Noppoo White Mx Blue     KBC Poker Mx Red    IBM Model M 1391401    Dell AT101w Black Black ALPS
Offline phx
« Reply #2 on: Tue, 23 April 2013, 10:13:32 »
Offline CommunistWitchDr
  • >implying keyboards
« Reply #3 on: Tue, 23 April 2013, 10:26:40 »
A very minor difference in the function layer.
Offline piou
« Reply #4 on: Tue, 23 April 2013, 10:54:19 »
If you are from EU and want the stealth but heard it will not get released because of the FIlco patent you should wait a bit .. @CoolerMaster tweeted at me and said "@piouql Just got word concerning the #CMStealth It might actually be released in the EU, but without backlights. Will keep you updated :)"
so maybe we will see some QFR stealths in europe :)
Offline Carter
  • CM Storm Rep
  • * Commercial Vendor
« Reply #5 on: Tue, 23 April 2013, 12:17:13 »
Technically there are a couple differences.
-12KRO via USB
-Repeat rate is now adjustable (PS/2 only)
