Author Topic: KBT Pure and LED voltages, or custom boards and LED voltages  (Read 1622 times)
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« on: Thu, 25 April 2013, 10:12:49 »
So I purchased these LEDs that were labeled as "Cyan" and when I install them they are green. I contact the seller and they tell me "please use 4.2-4.6V VOLTAGE try again, if use 3.2V-3.6V, the LED's may be green color." So is it possible to swap a resistor somewhere on a Pure to get more volts?
If it isn't possible, do any custom Korean keyboards allow voltage regulation in the firmware?
Offline Tarzan
  • formerly known as Greystoke
Re: KBT Pure and LED voltages, or custom boards and LED voltages
« Reply #1 on: Thu, 25 April 2013, 10:33:36 »
What was the part number for the LEDs?  I'm looking for green ones, myself.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
« Reply #2 on: Thu, 25 April 2013, 11:06:01 »
How many do you need? I purchased 1000 so I can sell you leftovers at cost +shipping which is pretty much $6 for 100.
Offline Tarzan
« Reply #3 on: Thu, 25 April 2013, 11:10:07 »
I could use 200 if you have that many to spare?  Looking to do a 109-key board plus an 83-key TG3.
Offline regack
« Reply #4 on: Fri, 26 April 2013, 08:22:13 »
Maybe?   From what I remember of the back of the Pure, there is what looks like some kind of driver for the LED matrix and some transistors and caps and stuff.  There might be 1 resistor per segment or 1 for the whole thing.  Unfortunately, the best way to find out how/what to change it is to essentially reverse engineer how it's built.  Not sure if anyone has done that already...
