Author Topic: Poker 2  (Read 7898 times)
Offline remedyhalopc
Poker 2
« on: Thu, 25 April 2013, 18:53:22 »
What's the word on these? Do you guys have any information you can share like an ETA/Price point!?
Offline ShakeR
  • * Moderator
    • http://mechanicalkeyboards.com
Re: Poker 2
« Reply #1 on: Mon, 13 May 2013, 10:59:38 »
Hope to have the order visible on MK Incoming in an hour or two.
https://mechanicalkeyboards.com/incoming.php
MechanicalKeyboards.com - What do you type on?
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
Re: Poker 2
« Reply #2 on: Mon, 13 May 2013, 15:17:07 »
It's on the site and currently priced just over $100. Going to be hard pressed NOT to buy one.  :))
Offline Dianoda
Re: Poker 2
« Reply #3 on: Thu, 16 May 2013, 10:05:55 »
Yeah, this is pretty much an insta order for me - plate mounted (edit - okay, I'm not so sure about the plate mounting - can someone confirm whether the Poker 2 has a plate or not?) and ready for LEDs, PBT keycaps, a layout compatible with most keycap sets.  Looks really nice.
« Last Edit: Thu, 16 May 2013, 12:27:40 by Dianoda »
Offline ShakeR
  • * Moderator
Re: Poker 2
« Reply #4 on: Fri, 17 May 2013, 13:53:18 »
They're PCB mounted as per the description.  I'm pretty sure that's how it was originally posted.  Let me know if I'm missing something, but you should be good to go :)
Offline Dianoda
Re: Poker 2
« Reply #5 on: Fri, 17 May 2013, 14:15:22 »
The listing on mechancialkeyboards.com indicates that the poker 2 is PCB mount, but I've read about there being a plate in the poker 2 in a few places (I think it was mentioned on vortex's FB page, and a few Chinese sites, etc.) - so I'm not sure what is correct - maybe there are multiple versions of the poker 2?  Can you confirm whether there is a plate or not when your stock arrives?
Offline ShakeR
  • * Moderator
Re: Poker 2
« Reply #6 on: Fri, 17 May 2013, 14:51:18 »
Absolutely.
Offline Dianoda
Re: Poker 2
« Reply #7 on: Fri, 17 May 2013, 16:12:23 »
Offline PandaSPUR
Re: Poker 2
« Reply #8 on: Tue, 21 May 2013, 14:46:51 »
Any idea when you'll get Poker 2s with backlighting?
Home:
Das Keyboard - MX Browns - Vortex Grey Side-Printed PBT Caps
Work:
KBT Pure - iKBC Aluminum Case - MX Reds
Vortex Poker II - Frosty on Lime Acrylic Case - MX Clears
Offline lightsout714
Re: Poker 2
« Reply #9 on: Wed, 22 May 2013, 20:48:06 »
I also would like to know if it plate mounted or not. Someone posted pictures of a plate. Hoping its PCB for easy switch swapping.
Offline i3oilermaker
  • techkeys.us
    • TechKeys
Re: Poker 2
« Reply #10 on: Wed, 22 May 2013, 20:57:07 »
I am told the Poker 2 is plate mounted.
Offline Dubsgalore
Re: Poker 2
« Reply #11 on: Wed, 22 May 2013, 21:06:56 »
if i had the $100..
