Author Topic: The Living Soldering Thread  (Read 2488290 times)
Offline JPG
  • Model F is my new passion!
Re: The Living Soldering Thread
« Reply #1350 on: Fri, 25 October 2013, 12:29:08 »
Also, 888D has been ordered! Can't wait!
Wahoo!  Join the club!   :thumb:  I think you'll like it.
I'm sure I will. Looks like a really nice station.
Managed to find some flux & wick. Also picked up some isopropyl alcohol, lint free wipes, an alcohol dispenser, and a bunch of other stuff.
All I need now is a table.. :rolleyes:
Kitchen table works fine, until you mess up or your parents see you  :p
« Reply #1351 on: Fri, 25 October 2013, 12:31:17 »
What if I don't have a kitchen table? :))
(i don't actually have a kitchen table) :|
I want to make one out of MDF and cheap wood but.. effort :))
Offline JPG
« Reply #1352 on: Fri, 25 October 2013, 12:48:28 »
Get one of these (they are sold 50$ near where I live)
http://www.costco.ca/Centre-fold-Resin-Table.product.10344500.html
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #1353 on: Fri, 25 October 2013, 13:20:24 »
There's a worktable write up in the earlier part of this exact thread, in fact.
« Reply #1354 on: Fri, 25 October 2013, 13:21:44 »
Yeah, I saw that. It's nice. I've already made my primary desk ( as seen here : http://imgur.com/a/32FAJ ), I would probably just downsize it.
Offline HPE1000
  • Keycap Paparazzo
« Reply #1355 on: Fri, 25 October 2013, 13:29:22 »
Copying logan with that graphics card coaster?  :p
« Reply #1356 on: Fri, 25 October 2013, 20:00:03 »
I use a cheap card table that was free to me.  You could easily find something similar at a thrift shop I'm sure, for probably 5 or 10 dollars.  It's not classy or nice by any means, but it gets the job done and folds up real nice for storage and transportation.  :)
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #1357 on: Fri, 25 October 2013, 21:21:23 »
Need your opinion...  I spent $50 on this NEW soldering station.  It looks like a rebranded version of this: http://hobbyking.com/hobbyking/store/__19240__Soldering_Station_with_Adjustable_Heat_Range_USA_Warehouse_.html  (the case looks a little different)
I used it once to repair a usb chip.  I pulled it out last night and the power switch seams to be malfunctioning.  When I flip the switch to ON, the light flashes sometimes but it does not come on.  I can hold the tip in my hand to verify it is not warming up.  If I turn the switch ON and OFF about 10-15 times, I can get it to turn on.
I have emailed the company I bought it from to see if I can get it replaced or get a credit for its value towards another soldering station.
Is this soldering stations usually reliable and do I just have a lemon here?  Is it worth my while to move to a better brand like Weller?
40991-040993-140995-2
« Last Edit: Fri, 25 October 2013, 22:08:51 by swill »
Offline damorgue
    • Personal portfolio
« Reply #1358 on: Sun, 27 October 2013, 04:30:36 »
If you read my post one one or two pages back I give a quite detailed description of it, and also what is likely wrong with yours. I fixed one of mine which had similar symptoms. The solder joints in the pen are likely quite bad. Do you have something else you can solder with to fix it?
« Last Edit: Sun, 27 October 2013, 04:32:27 by damorgue »
Offline MJ45
  • HHKB Pro
« Reply #1359 on: Sun, 27 October 2013, 08:04:03 »
I know that some may have a tight budget but some of these clones are not worth it in the long run. You are better off buying a quality name brand ( Haako, Weller, ect.) for a dependable soldering station for a little more.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #1360 on: Sun, 27 October 2013, 18:45:26 »
Perfect thank you.  I will wait till they get back to me before I start taking it apart.  Good to know that I should start by testing the pen.  I would not have started there...
I am going to see if I can return it and have them credit the value if the one I bought towards a Weller WES51.  I hate owning crap tools, its not worth it.  It will cost a lot more, but at least I know what I am getting...
Thanks for the feedback, I appreciate it.
Offline jalli
« Reply #1361 on: Sun, 27 October 2013, 22:29:14 »
One thing I don't see listed here are SMD Flow tips (Well based), these can be a bit hard to come by in some countries due to patents and such but they are really handy for SMD work:
Hakko has BCM/CM series but I have not seen them in North America, you can buy the aftermarket Plato ones though:
Plato HS-0531 / HS-0530: https://www.google.com/shopping/product/12244824029415007260
Here is a youtube video showing the use of a flow tip:
Antonia
« Reply #1362 on: Sun, 27 October 2013, 22:47:21 »
http://www.bdent.com/catalogsearch/result/?q=bcm
http://www.bdent.com/catalogsearch/result/index/no_cache/1/?p=2&q=bc
They're only for the FM stations though. There are similar ones for the 888D and other irons, but without the solder well in the tip - Shape BC/C
Offline jalli
« Reply #1363 on: Sun, 27 October 2013, 23:02:25 »
Yeah, if anyone finds a T18 (888D) flow tip please link or give a heads up.
Antonia
« Reply #1364 on: Sun, 27 October 2013, 23:18:32 »
What do you mean by flow tip? Do you mean one with a solder well? According to the hakko site, those don't exist for the 888D. The BC/C I linked before is the closest you'll get.
Offline jalli
« Reply #1365 on: Sun, 27 October 2013, 23:35:02 »
Yeah, sorry about the terminology, everyone seems to have different names for tips with solder wells in them.
As far as I understand Hakko ran into some (patent) legal issues with these sorts of tips and that's the reason we can't buy them (they might still be available in other parts of the world, if anyone finds them pls give a heads up/link).
There are however aftermarket(3rd party) tips that will fit the 888d such as the tips that I listed.
Here is the manifacturer link:
http://www.techspray.com/p-132-soldering-tips-hakko.aspx
Here is the datasheet:
http://www.techspray.com/controls/techspray.tds/tds.ashx?id=132
Antonia
« Reply #1366 on: Mon, 28 October 2013, 07:39:45 »
Came today with a few tips aswell as a solder reel holder. Expecting a load of stuff from ebay soon: wick, flux, kimwipes, and some more stuff.
Dancap have a really awful website and you have to pay through bank transfer or cheque. However, their service is very, very good indeed. Would highly recommend anyone in the EU/UK using them!
I really love the colours of this thing. It feels very high quality too, looking forward to using it!
« Last Edit: Mon, 28 October 2013, 07:42:20 by Photekq »
Offline MJ45
  • HHKB Pro
« Reply #1367 on: Mon, 28 October 2013, 09:47:19 »
Your all set now the Hakko's are a great, the best in their price range. I love using the one I have.
Offline meiosis
  • Time
« Reply #1368 on: Tue, 29 October 2013, 00:59:12 »
When soldering the super small SMD components do I need soldering flux?
Keyboards:
Aripeko TKL
« Reply #1369 on: Tue, 29 October 2013, 02:55:02 »
Did you get a new camera recently too?   :eek:
Regardless, lookin good!!  I'm positive you'll enjoy it.
Offline jalli
« Reply #1370 on: Tue, 29 October 2013, 08:15:39 »
If you need to ask this question the answer is YES, there are ways to do without but in general flux can always be cleaned off and it's better to have to much than to little.
If you are just soldering 2 pole SMD parts (resistors, capacitors, diodes, etc) you can use fine rosin core flux, if you are doing anything with a larger pin count and fine pins  extra flux becomes necessary unless the components are all brand spanking new and don't have any oxide on them (factory new).
Antonia
« Reply #1371 on: Tue, 29 October 2013, 15:56:02 »
Haha, no. I just took the photos while the sun was out so the lighting was good.
Offline HPE1000
  • Keycap Paparazzo
« Reply #1372 on: Tue, 29 October 2013, 16:02:47 »
So, anyone remember how long the yihua 936 took to get to them? Shipping was around 16 dollars and I didn't get a tracking number..
Offline Dgsbllx
« Reply #1373 on: Tue, 29 October 2013, 16:07:27 »
Photekq, nice pictures. I'm thinking of purchasing an fx888d also, and dancap looks as good as any place to buy from. Will just the T18-B tip that it comes with be enough to start soldering a phantom? or do I need others?
« Reply #1374 on: Tue, 29 October 2013, 16:12:14 »
I would get a T18-D16 or T18-D24 for soldering a phantom. The stock tip isn't a chisel tip, so it wouldn't be very good for soldering a keyboard.
Offline esoomenona
  • Gnillort?
« Reply #1375 on: Tue, 29 October 2013, 16:13:20 »
I know it's been suggested since the first page, but why are chisel tips preferred to the pointed ones?
Offline HPE1000
  • Keycap Paparazzo
« Reply #1376 on: Tue, 29 October 2013, 16:14:25 »
I believe chisel tips have better heat transfer.
Offline Dgsbllx
« Reply #1377 on: Tue, 29 October 2013, 16:15:00 »
Cheers I'll send them an email tomorrow  :thumb:
Do the same tips apply for an ergodox?
« Reply #1378 on: Tue, 29 October 2013, 16:18:01 »
Yes, although it may be worth getting a D12 or D16 since I believe there is some trickier soldering on the ergodox.
It enables faster heat transfer.
Offline Dgsbllx
« Reply #1379 on: Tue, 29 October 2013, 16:20:06 »
Thanks a lot  :D
« Reply #1380 on: Tue, 29 October 2013, 16:21:54 »
Thanks a lot  :D
No worries. Any time :)
Offline HPE1000
  • Keycap Paparazzo
« Reply #1381 on: Tue, 29 October 2013, 16:27:30 »
So does this(the tip) look like it will be thick enough to desolder with? I think so, but I know nothing lol
« Reply #1382 on: Tue, 29 October 2013, 16:28:47 »
Are you able to desolder it within two seconds of placing the iron on the joint? If so, it's fine.
Offline HPE1000
  • Keycap Paparazzo
« Reply #1383 on: Tue, 29 October 2013, 16:31:48 »
I don't know, soldering iron has not shown up yet.  :-[
« Reply #1384 on: Tue, 29 October 2013, 16:34:45 »
Ah right. What iron is it, and what's the diameter of the tip?
Offline HPE1000
  • Keycap Paparazzo
« Reply #1385 on: Tue, 29 October 2013, 16:40:20 »
Yihua 936, the tip is 1.6.
« Reply #1386 on: Tue, 29 October 2013, 16:42:59 »
I reckon that'll be fine. If you find that it takes a long time to melt the solder then maybe get a 2.4, which is what I used when I had a yihua.
Take a look at this :
t=18m35s
« Last Edit: Tue, 29 October 2013, 16:46:32 by Photekq »
Offline BakaPhoenix
« Reply #1387 on: Sun, 03 November 2013, 12:47:56 »
In the first post as a under 50$ soldering iron there is a weller station...
In italy there is a model called LAFAYETTE SSR-5 that looks similar to the weller:
http://www.ebay.it/itm/261230496152?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 (sorry if the link is in italian)
Are they the same soldering iron with different brand?
I can safely take it?
Thanks :D
p.s. that weller i can't find it in italy XD(i find some other model at 100 €)
« Last Edit: Sun, 03 November 2013, 12:50:27 by BakaPhoenix »
Offline HPE1000
  • Keycap Paparazzo
« Reply #1388 on: Sun, 03 November 2013, 13:44:58 »
So I got the yihua 936 a couple days ago, it worked really good and I think I did a great job for my first time soldering. I changed my cherry mx blues to ghetto greens and stickered them. Everything worked and I didn't have any problems :D
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #1389 on: Mon, 04 November 2013, 07:57:44 »
Gratz on the successful mod job
Offline BakaPhoenix
« Reply #1390 on: Wed, 06 November 2013, 13:58:47 »
On what temp I need to set my solder iron to solder/desolder LED?
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #1391 on: Wed, 06 November 2013, 14:02:48 »
Keep it to right at the temperature to melt the solder you're using.  63/37 usually is around 380*F
Offline BakaPhoenix
« Reply #1392 on: Wed, 06 November 2013, 14:16:37 »
Since iwant to change some switches on a keyboard with led (CM storm Quickfire tk), do you know aproximatively the temp for that?
Thanks :D
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #1393 on: Wed, 06 November 2013, 14:35:29 »
Thanks :D
Same thing, you want the solder to just get hot enough to melt and nothing more.
Offline Melvang
« Reply #1394 on: Wed, 06 November 2013, 15:14:02 »
Although to hot can be more forgiving than to cold.  Reason being if it is to hot it will just melt quicker and you can get the solder sucked up and out a touch quicker.  If it is to cold then you have to sit there and wait for the solder to melt while that heat moves up the pin for the switch and could start melting stuff in the switch.
Offline BakaPhoenix
« Reply #1395 on: Wed, 06 November 2013, 15:37:34 »
So, you are saing that if you put an higher temp there is less time to let the heat travel all the way to the switch/LED?
Offline Melvang
« Reply #1396 on: Wed, 06 November 2013, 16:40:57 »
Correct but you since the amount of heat at the joint is higher you need to be much quicker in getting the solder out or bad things can happen quicker.
Edit:  Also keep in mind that the temp suggestions already given here are for leaded solder which melts much lower than lead free solder.  If desoldering a stock board you will need to turn the heat up anyway due to pretty much all companies using lead free solder to make an attempt to be RoHS compliant.
« Last Edit: Wed, 06 November 2013, 16:52:20 by Melvang »
Offline BakaPhoenix
« Reply #1397 on: Wed, 06 November 2013, 17:22:38 »
300° C for 2-3 will be fine? or it too much?
Offline Melvang
« Reply #1398 on: Thu, 07 November 2013, 17:59:42 »
Can't help you there sorry.  I just don't have a lot of experience with desoldering.  I just understand the mechanics and then physics behind it.
Offline Pacifist
  • on hiatus
« Reply #1399 on: Thu, 07 November 2013, 23:12:14 »
I'm really confused. In order to only solder in ~50 switches, and not desolder, what do I need? Do I need the wick and a soldering iron or just an iron? And are there any cheaper irons? How about this? http://www.amazon.com/60-Watts-Soldering-Iron-listed/dp/B0006NGZK0/ref=zg_bs_13837391_1 Going to buy http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=19240.html
Also I will probally buy http://www.parts-express.com/pe/showdetl.cfm?partnumber=360-670 http://www.amazon.com/SE-MZ101B-Helping-Hands-Magnifying/dp/B000RB38X8/ref=sr_1_8?ie=UTF8&qid=1383887070&sr=8-8&keywords=soldering+iron(its cheaper on amazon), the helping hands, which will help with lubing switches and soldering.
So just need to solder in switches, all the other tooling will be pre done. What's the cheapest things I need to do so? what other stuff besides the yihua do I need to buy?
« Last Edit: Fri, 08 November 2013, 00:12:19 by Pacifist »
