Author Topic: Leopold FC660C  (Read 394376 times)
Offline kmba
  • Formerly tameone
Re: Leopold FC660C
« Reply #650 on: Fri, 19 May 2017, 23:48:23 »
Lots of people have!  These are some of the nicer, or perhaps the nicest, mx sliders on the market.  The diameter is slightly smaller than stock sliders so they lead to a little more key wobble but nothing excessive, but they're also longer so you don't have any problems with key cap compatibility.  As always, you still have to use a topre spacebar.
keyboards.
Offline varmemester
Re: Leopold FC660C
« Reply #651 on: Tue, 23 May 2017, 06:13:21 »
Thank you!
Offline Heliobb
Re: Leopold FC660C
« Reply #652 on: Wed, 28 June 2017, 04:20:58 »
I would like to replace the USB controller on my Leopold.
Do you know if it's possible to find this part?
I completely open the USB plug to fix it
It's now working but it's very unstable.
This is not a good idea to put usb plug like this. I love how Novatouch made this http://i.imgur.com/acWrscZ.jpg
« Last Edit: Wed, 28 June 2017, 07:01:07 by Heliobb »
Novatouch TKL - Leopold FC660C - PBT my life.
Offline Heliobb
Re: Leopold FC660C
« Reply #653 on: Wed, 28 June 2017, 05:30:53 »
Offline Heliobb
Re: Leopold FC660C
« Reply #654 on: Thu, 29 June 2017, 07:23:56 »
The seller widebasket from eBay told me Leopold don't sell the part for the keyboard.
Offline hasu
  • @tmk
Re: Leopold FC660C
« Reply #655 on: Thu, 29 June 2017, 07:33:53 »
if you can replace the connector your self what you need is exactly Hirose UX60SC-MB-5ST.
Offline Vespene
Re: Leopold FC660C
« Reply #656 on: Sun, 22 July 2018, 23:10:12 »
Is it possible to put the silencing pad from a FC660M in a FC660C without issues? Has anyone done this? I'm curious to see what this would sound like.
Offline itbesandrodoe
Re: Leopold FC660C
« Reply #657 on: Tue, 12 February 2019, 20:21:01 »
Great review, I have tried both of the boards and agree that the HHKB is just the better fit. I do love the looks of the leopold however.
