Author Topic: Information about a Lexmark M15  (Read 1386 times)
Offline TheRavenDog
« on: Fri, 26 April 2013, 00:45:36 »
Recently, I had the good fortune of acquiring a Lexmark M15.
But I can't seem to find any information about it's "Part No." and "ID No."
It is a Part No: 1378300 with ID No: 327. I think the 1378300 was the first of the Model M15s. I think the ID No. is the unit's unique serial number.
The only google search for the part number is this  page: http://www.flickr.com/photos/njr/406263107/in/photostream/.
If the ID No. is sequential, then I may have found the 327th M15 every made! It certainly is one of the earliest production dates I've seen for a M15 (after a quick look at clickykeyboards.com).
Does anyone know anything more about the Part and ID numbers?
Thanks,
Chris Petersen.
The dream...                     The reality...
Offline rootwyrm
  • The Hands of Steel
    • My Website!
Re: Information about a Lexmark M15
« Reply #1 on: Fri, 26 April 2013, 02:10:06 »
The part number is the OPN - so when you ordered an M15 from Options, you specified a PN 13H6689 not an "M15." Plt No L1 confirms it as Lexmark, Kentucky plant (this is consistent across all IBM keyboards) - which is the only plant to manufacture the M15. The OPN distinction there is important - you've got an extremely rare Lexmark branded M15.
The M15 serial numbers started at 0000000 - so it would technically be the 328th. However, the highest observed serial number for '94 (reset to 0 for '95 for some reason) is 0001895 - with the lowest seen in the wild for a '94 being 19. And it's unknown if the Lemark branded ones are in sequence with or separate from the Options sequence.
Given the spread and other data, I suspect the entire production run for 1994 may be less than 3000 units and they're shared for both PNs.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
