Author Topic: MX Brown with 45g and 55g  (Read 3211 times)
Offline Index
« on: Fri, 26 April 2013, 12:29:12 »
With the closing with the upcoming GH60, DSA Retro GB's, and Calavera's PsuedoGB on Korean Springs, I was wondering if anyone has had experience with 45g and/or 55g springs on MX Browns. If so, could you please share your experience(s)?
Gaming Keyboard: Leopold FC200RT/ABN
Work Keyboard: HHKB Pro 2 PD-KB400B
Offline OwnageHN
Re: MX Brown with 45g and 55g
« Reply #1 on: Fri, 26 April 2013, 13:45:38 »
I'm confused.  Are you asking for our opinion on the difference between MX Brown and MX Clear?
« Reply #2 on: Fri, 26 April 2013, 13:46:40 »
No, MX Browns with Korean springs. IMO, the 55g are indistinguishable from stock brown springs. I have yet to try the 45g Koreans.
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #3 on: Fri, 26 April 2013, 13:51:07 »
You can also try 50g korean springs
-Enzo Ferrari
Offline OwnageHN
« Reply #4 on: Fri, 26 April 2013, 13:55:40 »
Oh sorry, I'm still new at this stuff.  From what I've learned, MX Clears are "like a firmer MX Brown" where Clears are 55g and Browns are 45g.  I guess a 55g Brown is different from a 55g Clear because of the tactile bump?
« Reply #5 on: Fri, 26 April 2013, 14:03:35 »
Actually, clears are more than 65cN at actuation, due to the large tactile bump. Browns are 45cN at actuation.
Korean springs are measured by "bottom out" force, or full compression. Cherry specs are at actuation. Browns are about 60cN at full compression, which I feel is practically equivalent to those 55g Korean springs.
Clears are over 100cN at full compression.
Offline OwnageHN
« Reply #6 on: Fri, 26 April 2013, 14:33:40 »
TIL
Offline Abacus1234
« Reply #7 on: Fri, 26 April 2013, 14:57:44 »
I would not mind trying cherry browns that are lighter than the stock springs. At first, when I started using mechanicals, I found the lighter force caused more typos. But now that I am used to it, I keep thinking I'd like to try something even lighter. Typing on a mechanical, if nothing else, has made me become more accurate.
