Author Topic: ALU Aluminium Tastatur Heros Computer Bundeswehr Bw inkl Scrollball  (Read 9545 times)
Offline foxtrott
Offline Tarzan
  • formerly known as Greystoke
Re: ALU Aluminium Tastatur Heros Computer Bundeswehr Bw inkl Scrollball
« Reply #1 on: Fri, 26 April 2013, 12:51:46 »
... with Doubleshots  :D
http://www.ebay.de/itm/261057855871?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Now THAT'S a nice case!
Idiosyncratic key layout, something weird going on around the number pad area, but I kept going back to pictures of the case.  Aluminum.  Badass.
Offline foxtrott
Offline Tarzan
« Reply #3 on: Fri, 26 April 2013, 13:05:07 »
That's just too tasty to pass up!  Where's that Sofort-Kaufen button?
Crap.  Not willing to sell/ship to the US.
Anyone in the EU willing to proxy?  My regular guy is probably pretty tired of my acquisitions by now!   ;D
Seriously, proxy help?
Offline codyeatworld
« Reply #4 on: Fri, 26 April 2013, 13:17:50 »
Also interested in a proxy!
7 available / 2 sold?
Offline Tarzan
« Reply #5 on: Fri, 26 April 2013, 13:20:13 »
That's what the ad says...
I posted a request on DT as well, bit late in the day (night) but maybe someone will volunteer.
Offline Mugen
  • O-Rings are the murderers of keyboard souls
« Reply #6 on: Fri, 26 April 2013, 13:23:30 »
Is this a cherry board?
Offline Dianoda
« Reply #7 on: Fri, 26 April 2013, 13:26:33 »
Not exactly, not cherry switches but it uses the same stem shape as cherry mx.  Check the deskauthority wiki link posted above.
Offline Tarzan
« Reply #8 on: Fri, 26 April 2013, 13:43:58 »
I got a response from a fellow DT-er, keeping my fingers crossed...
 :-X
Offline esoomenona
  • Gnillort?
« Reply #9 on: Fri, 26 April 2013, 13:51:13 »
Maybe one person could proxy a couple to save on shipping and then they get split here? I may be interested as well.
Offline Tarzan
« Reply #10 on: Fri, 26 April 2013, 13:54:38 »
It's a possibility, but I was just looking at the specs on that military-grade hardware.  3.38 kg.  Each.
Holy smokes.  Probably cheaper to buy a ticket to Berlin and bring a couple back in carry-on!
Offline Tarzan
« Reply #11 on: Fri, 26 April 2013, 14:04:47 »
Update from DT proxy:
Yeah, shouldnt be a problem at all. Word of warning though:
1. These keyboards are HEAVY. Shipping to the US will most likely be 40€ per keyboard
2. Marquardt switches do not age all that well, ive proxied several of these keyboards for people and some had worn out switches.
I've tried my share of marquardt switches on several keyboards (HEROS, MiniErgo, and a NIB Marquardt compact TKL with dyesubs) and they are not that great.
They are a bit of a mix of MX Black and MX Brown, a scratchier, less smooth linear switch. Though they are enjoyable, I suggest you really think this purchase and the shipping costs over...it would suck to end up with a 3.5kg brick that you do not enjoy using.
On a positive note the HEROS keyboard can be easily converted to a ps2 plug, you just need to solder the correct pins off the DSUB plug and attach them to a ps2 plug.
So, what's the consensus?  Go for it?  Get a shipping quote first?
Edit: I have another package of keyboards inbound from Germany, the shipping was 34,00 EUR with DHL.  This is for a flat-rate box up to 5kg.  Unfortunately for the Hero boards, that would mean one board per, maybe cram a cheap G80-1800 in as well.
Edit2: Well, I'm going to get one of these, see how massive they are IRL.  There's at least one ad on eBay.de for the entire military computer+case+keyboard, it looks like the world's largest Dolch test set:
http://www.ebay.de/itm/Bundeswehr-Computer-HEROS-19-Zoll-PC-Modding-Basis-/320758558800?pt=DE_Computer_Sonstige&hash=item4aaeb33050
Apparently these keyboards have come up for sale before, the old GH thread is linked back via DT reference:
http://geekhack.org/index.php?topic=8016.0
Wish me luck, or question my sanity!
« Last Edit: Fri, 26 April 2013, 14:57:37 by Greystoke »
Offline BlueBär
« Reply #12 on: Sat, 27 April 2013, 08:14:00 »
Apparently (idk if you guys got that translated) these keyboards were used for computer systems in headquarters or even computer based weapon systems (think of artillery, rockets and AA). Interesting.
Offline esoomenona
  • Gnillort?
« Reply #13 on: Sat, 27 April 2013, 08:21:29 »
Once you pass the 5kg limit, isn't the next limit much higher or unlimited for like $75? If even three came in that shipment, each person already saves. Clearly, the more included the better.
Offline BunnyLake
  • The OG HHKB Master
  • X
« Reply #14 on: Sat, 27 April 2013, 08:22:17 »
i can proxy for anyone here
Offline BunnyLake
  • X
« Reply #15 on: Sat, 27 April 2013, 08:25:57 »
also i may be able to ship em free when they get here, i might not, but if i cant i can just proxy them as normal, but more often that not i can ship through my wifes works shipping dept
Offline REVENGE
« Reply #16 on: Sat, 27 April 2013, 08:26:02 »
I'm in on this one. We should do combined shipping, I would be willing to distribute.
Offline Tarzan
« Reply #17 on: Sat, 27 April 2013, 08:41:37 »
I sent a note to the eBay.de seller, asking how much shipping would be if I purchased all four remaining HEROS keyboards.  Not sure if he's even willing to ship internationally, but figured I'd ask.   :rolleyes:
Offline foxtrott
« Reply #18 on: Sat, 27 April 2013, 09:06:45 »
I bought one.
'm really excited about the quality  :)
Offline Tarzan
« Reply #19 on: Wed, 01 May 2013, 13:21:17 »
Looks like I got all the remaining ones.  Now to find out how painful it will be to ship these solid chunks of aluminum across the Atlantic.   :-X
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #20 on: Wed, 01 May 2013, 13:41:54 »
Looking at the photos, it appears it might be possible to replace the PCB with one of a G80-3000. At the least it appears the spacing between key sections is the same. Even if a new plate needed to be cut it might be worth a go if the Marquardts suck to salvage the nice metal cases.
Offline Tarzan
« Reply #21 on: Wed, 01 May 2013, 14:00:06 »
That would make a nice backup plan!  I'm crossing my fingers that the units I've got on the way aren't in too bad shape.  [Kind of a crap-shoot with military surplus stuff.  Either it's practically brand new and never used, or it's beat all to hell.]  The description of Marquardt switches as being a cross between Cherry MX Brown and MX Black is kind of appealing, I like both of these switch types, but the possibility of building a nice G80 with MX Whites or Greens in this aluminum case is tempting.  :-\
« Reply #22 on: Wed, 01 May 2013, 14:09:09 »
Yes that is typically the case with military items. Either it was warehoused and never used and is being sold because they no longer use that model, or it was from the field and was pulled because 'no longer serviceable'. Even if the keyboard is in poor condition, the metal cases should still be refinishable even in the worst of case.
Offline ed_avis
« Reply #23 on: Thu, 02 May 2013, 04:01:30 »
I'm tempted to get this Marquardt just to be able to say that I have a Marquardt with Marquardt Marquardts.
Offline Tarzan
« Reply #24 on: Sat, 04 May 2013, 21:03:50 »
It looks like there will be two of these keyboards available, if anyone is looking for one.  I bought four of them, but just need two - for myself and one other poster.
Price is $75.00 per keyboard, shipped to a CONUS address.  Let me know if you're interested, I figured I'd post them here before creating a thread in the Classifieds forum.
« Reply #25 on: Sun, 05 May 2013, 07:51:46 »
Now that you have them can you take a measure (or test fit if you have one) if G80-3000 will fit inside it? If it will I am likely to buy one.
Offline Tarzan
« Reply #26 on: Sun, 05 May 2013, 09:58:47 »
The keyboards have all been spoken for.
Offline Tarzan
« Reply #27 on: Sun, 05 May 2013, 10:05:14 »
I'll let you know once I have one to take apart.  I don't think I have a G80-3000 to try, only G80-1501 and G80-1800, but I can measure the inside dimensions.
Offline HongKongFui
  • No, you couldn't
« Reply #28 on: Sun, 05 May 2013, 14:13:02 »
got me one of those also and I'm curious what the GH- audience will say. I bought it only to see the doubleshots and they're really... strange. thin caps but they feel nice and mine are in perfect condition. I'm not into changing pcb from one board to another so I can't say anything about that G80 thing.
if you want some fotos before you get yours just ask...
Offline REVENGE
« Reply #29 on: Sun, 05 May 2013, 15:39:26 »
I am mildly interested in attempting to design a custom PCB for it. It would be based on one of the 87-key PCB layouts floating around since I cannot find one for a full size board.
Also, we have very good pics and documentation of this keyboard here: http://deskthority.net/wiki/Marquardt_Military_Keyboard_7069.3111, but no great pics of the key caps.
Offline HongKongFui
  • No, you couldn't
« Reply #30 on: Mon, 06 May 2013, 16:11:56 »
From left to the right: Marquardt Cap - Cherry Cap - TA Gabriele 7007L cap  --  sorry for the bad quality
« Reply #31 on: Mon, 06 May 2013, 16:48:58 »
Marquart caps look like SP caps. Your TA dyesub seems to be smaller than the Cherry doubleshot. How odd, my TA dyesubs are the same size as Cherry doubleshot.
Offline REVENGE
« Reply #32 on: Mon, 06 May 2013, 20:35:55 »
I'm pretty sure I've had some of those caps (like the Dot cap) in the random grab bags.
Offline HongKongFui
  • No, you couldn't
« Reply #33 on: Thu, 09 May 2013, 06:02:26 »
a little offtopic regarding the size of the TA dyesubs, sorry for that:
Oh, I noticed that before but I think that special micro key is a bit smaller than the others?! to check that I took 2 letter keys and again the "micro" key hoping it's not that extreme- I think pics 3 and 4 on which I stacked them up to see the difference show that that micro key really is a lil bit smaller (or is it me that wants to see it that way?):
Sorry again for the quality. next time I'll use my galaxy, the digicam is too old...
EDIT: What I forgot: The TA Dyesubs are really great as they reduce the sound really really good compared to the original caps of my pure.
« Last Edit: Thu, 09 May 2013, 06:29:19 by HongKongFui »
« Reply #34 on: Thu, 09 May 2013, 09:15:11 »
We need a legend that says micro...must make key smaller too! Micro key is micro.
Offline foxtrott
« Reply #35 on: Tue, 30 July 2013, 13:45:04 »
hello,
Edit: ok... i remove my post..
I hope it's ok that I post this here  :)
« Last Edit: Tue, 30 July 2013, 14:12:11 by foxtrott »
« Reply #36 on: Tue, 30 July 2013, 14:03:18 »
I would say that it isn't since you're circumventing the minimum post requirement for sales here.  I'd remove that post.
Offline foxtrott
« Reply #37 on: Tue, 30 July 2013, 14:15:13 »
sorry, deleted.
