Author Topic: Help Switch Top  (Read 1831 times)
Offline MxAll
Help Switch Top
« on: Fri, 26 April 2013, 17:33:20 »
I just got my CM Storm keyboard today.
The Crtl keyhold idk what you guys call it has Cherry written on it the stem goes through it. I could not manage to get it on.
So I took it off entirely. How do I put it back on?
This is what I did.
how can I put it back on?
Steel series 6gv2 Mx Black, Rosewill RK-9000i Mx Blues, CM Storm QF Mx Browns.
Offline ComradeSniper
  • HHKB Pro
Re: Help Switch Top
« Reply #1 on: Fri, 26 April 2013, 19:20:23 »
I'm confused how you got it off at all. Removing the switch top like in that video is not possible with your keyboard without desoldering the switch.
Offline MxAll
Re: Help Switch Top
« Reply #2 on: Fri, 26 April 2013, 21:38:21 »
hmm is there anyway to get it back on though?
I hate waiting and I love the Mx Cherry Brown switches and I want to use them now!
  • HHKB Pro
Re: Help Switch Top
« Reply #3 on: Fri, 26 April 2013, 22:53:14 »
Could you post a pic of where the switch used to be on the keyboard? I think it would be easier to understand that way.
And the keyboard arrived with the switch top detached?
Offline TheQsanity
  • SmallFry Lovin'
Re: Help Switch Top
« Reply #4 on: Sun, 28 April 2013, 03:18:15 »
CM Storm RF Mx Browns? Is that a new one?
I have never taken my switches off like that on a CM board.
Maybe you can take it off but not put it back on.
ListerLister was showing how to take the switch apart from a custom made plate. Usually you have to desolder each switch, then take it apart.
Do you know how to solder?
Take pictures of your keyboard that you need help with.
SmallFry! <3
Re: Help Switch Top
« Reply #5 on: Sun, 28 April 2013, 09:11:09 »
I think you might have broken the switch.. That video shows how to remove switch tops from a custom plate, not the stock QFR plate.
If you take pictures it'd be easier to identify the problem.
Offline remedyhalopc
Help Switch Top
« Reply #6 on: Sun, 28 April 2013, 10:02:55 »
Take pictures and let us know what the damage (if any) is. I have a spare brown you can have if you broke the housing.
