Author Topic: Has anyone used one of these?  (Read 3406 times)
Offline 1391406
« on: Sat, 27 April 2013, 15:27:39 »
Re: Has anyone used one of these?
« Reply #1 on: Sat, 27 April 2013, 15:33:50 »
The suspicious thing is that the "20 million" strokes rating. Aren't Model Ms rated at 50M or more?
I would ask the seller to pull a key and take a picture. That would tell all.
- D Trump 2026-09-28
« Reply #2 on: Sat, 27 April 2013, 20:21:54 »
That looks like a Key Tronic rubber dome keyboard. Box art does not match the keyboard. The info on the box is most likely completely irrelevant.
« Last Edit: Sat, 27 April 2013, 20:23:58 by Findecanor »
Offline 1391406
« Reply #3 on: Sat, 27 April 2013, 21:51:01 »
This is true.
Offline brtaylor92
« Reply #4 on: Sat, 27 April 2013, 23:41:13 »
Offline Rule16
  • R.I.P. SmallFry
« Reply #5 on: Sun, 28 April 2013, 00:24:02 »
That probably makes it a cherry mx switch because they used to be rated for 20 mil.
also... to original, its not ironic its called spacesaver, have you not seen the casing on old alps keyboards?
« Last Edit: Sun, 28 April 2013, 11:36:13 by Rule16 »
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
Offline rootwyrm
  • The Hands of Steel
    • My Website!
« Reply #6 on: Sun, 28 April 2013, 01:52:48 »
IBM never really emphasized the lifespan of the Model Ms or any buckling spring keyboards to my knowledge.
That's a bog-standard IBM-case-clone which was pretty common for many years. And no need for pictures.
That is a KeyTronic example with pretty good rubber domes. KeyTronic is the only manufacturer to ever use that "MADE IN USA" in the mold, and LR65976 is their old CSA number.
"I remain convinced I am the only person alive who has successfully worn out an IBM Model M mechanically."
Daily Drivers: Adesso 625 (NPKC PBT / Kailh Blue), Rosewill RK9000V2 (KC PBT / MX Brown), 1994 Model M13, Sun Type4, and the rare IBM 1394540.
Offline 1391406
« Reply #7 on: Sun, 28 April 2013, 03:15:01 »
Well, the mystery has been solved. Thanks, guys.
Offline rootwyrm
    • My Website!
« Reply #8 on: Sun, 28 April 2013, 04:14:33 »
Indeed. It's not bad for a rubber dome, to be quite honest, but it is most definitely not worth even half the seller's asking price there. That particular model is familiar to me as just about everyone on earth OEM'd it as their "cheap" keyboard as the clone era was taking off. (Hence the lack of any branding on it.) So you'll find it under a good two dozen names, with several dozen different box styles, but all the same keyboard.
