Author Topic: Where to find a mini usb to ps2 cable (NKRO)?  (Read 5347 times)
Offline csloan1218
  • Technomancer
« on: Sun, 28 April 2013, 00:22:45 »
I couldn't turn anything up on a quick glance on the web.
Ideally braided or sleeved.
Ducky DK9008 Shine II Blue LED Backlit (Red Cherry MX)
Leopold Linear Touch FC500RR/AB (Red Cherry MX)
Offline TotalChaos
  • Indy Game Coder
Re: Where to find a mini usb to ps2 cable (NKRO)?
« Reply #1 on: Sun, 28 April 2013, 00:41:42 »
Usually if a keyboard works on PS/2 then it comes with the proper cable or adapter.
What kind of keyboard (and model #) are you trying to connect to PS/2?
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #2 on: Sun, 28 April 2013, 00:45:14 »
There are two ways to do it:
1:  Order from Mimic.
2: Use one of the USB to PS/2 adapters.
Offline csloan1218
  • Technomancer
« Reply #3 on: Sun, 28 April 2013, 01:21:20 »
Particularly my ducky, but any mk with a detachable cable.
I think a good mini usb to ps2 would be a good solution, I could use an adapter but since I was looking for a braided cable why not kill 2 birds with one stone.
If thats the only option, I'll see what hes got.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #4 on: Sun, 28 April 2013, 01:27:14 »
I feel like a salesman when I say "He has literally what you want."
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #5 on: Sun, 28 April 2013, 09:32:33 »
Rosewill RK9000 comes with such a cable, perhaps Rosewill owner has one they are not using? Make WTB for.
Offline TotalChaos
  • Indy Game Coder
« Reply #6 on: Sun, 28 April 2013, 12:19:10 »
True.  And the cables are braided.  I am using all mine so I have none for sale.
Offline csloan1218
  • Technomancer
« Reply #7 on: Sun, 28 April 2013, 12:37:50 »
So looking at your signature, the cable is the only good thing about the rosewill?
Offline TotalChaos
  • Indy Game Coder
« Reply #8 on: Sun, 28 April 2013, 13:20:26 »
No.  The cables are completely awful.  They are ridiculously stiff and therefore transfer force into your USB connector, eventually cracking the solder joints and rendering the keyboard nonfunctional.
Normal cables lay down onto whatever surface u lay them on.
These cables magically lift themselves up into the air.  Mine currently goes 6 inches up then 6 back down then zigzags all over the place up and down and all around.   All that weight transfers directly into your USB port.  Its a total scam.
I have my stupid ridiculous ripoff Rosewill cable taped onto the keyboard to act as a strain-relief mechanism.  You should do the same.
But by golly, they are braided.
Offline csloan1218
  • Technomancer
« Reply #9 on: Sun, 28 April 2013, 13:42:03 »
Maybe I need to rethink getting one of those cables, at least from rosewill.
I think steel series has a cable that comes with their 7G, I wonder if it suffers the same issue as the rosewill?
Offline Rule16
  • R.I.P. SmallFry
« Reply #10 on: Sun, 28 April 2013, 14:40:44 »
I'm pretty sure the 7G's cable is attached.
| KB Paradise V60 Maias Quiet Click | Realforce 55gram 87U | MiniTouch (Ivory Hua-Jie) | Poker II | IBM Model F | Unicomp Ultraclassic | Dell AT101W (Black Alps) | WASD Code (Clear) |
Dvorak Only Zone
