Author Topic: [Question] Drawing custom keycaps  (Read 3857 times)
Offline feyd
« on: Sun, 28 April 2013, 12:32:50 »
Hi everyone!
I was asking how to mod my keyboard, I need wirte in 3 alphabets, and I wonder how can I drawn characters in my keycaps to look like a comercial keyboard and not like a homemade.
What technics can you recomend me? Stencil?
« Last Edit: Sun, 28 April 2013, 12:34:43 by feyd »
Offline BlueBär
Re: [Question] Drawing custom keycaps
« Reply #1 on: Sun, 28 April 2013, 12:38:48 »
Stencil will probably not be your best option, I highly doubt that the letters will come out very clean (or even readable if you're not very careful). An idea might be to buy keyboard stickers and cut out the letters. This will be the same amount of work since you would have to do the same for a stencil.
Also you could always get custom keycaps from WASD Keyboards but that is of course a lot more expensive.
Offline E TwentyNine
    • Some of My Keyboards
« Reply #2 on: Sun, 28 April 2013, 14:24:25 »
What alphabets?  Could be as simple as getting keyboard stickers (clear background) and put one on the top and one on the side of each key.
Offline TotalChaos
  • Indy Game Coder
« Reply #3 on: Tue, 30 April 2013, 04:35:02 »
Design your keycaps in your gfx software on your computer and upload them to WASDkeyboards.com custom keyboard designer.
This option requires using a Cherry MX switch compatible keyboard.
Offline keymaster
  • Topre Revolution Theorist
« Reply #4 on: Tue, 30 April 2013, 07:30:34 »
I believe litster is the resident rare keycap designer. Contact him for life-changing advice.
