Author Topic: Has anyone tried articulated arms for keyboards?  (Read 6908 times)
Offline Mandolin
  • Crystal Connoisseur
« on: Mon, 29 April 2013, 05:13:14 »
I saw something made by ergotron, and it's expensive as f***, but it looks amazing:
Its a articulated arm, kind of what the dentists use, for the keyboard (for the monitor also)
http://www.ergotron24.com/ergotron-lx-hd-table-with-swing-arm-and-keyboard-arm.html
I think it's not worth it, but if I had a ton of money, id try it. Maybe one could do some diy, but what for...
Artisan keycap Maker
Working on
- Custom keycaps
- Artkeycaps V2 sale
- Due chihuahua and demoncat orders
- Boobiecaps
- Optic fiber embedded keycaps
- Others
Offline Mandolin
Re: Has anyone tried articulated arms for keyboards?
« Reply #1 on: Wed, 01 May 2013, 13:41:31 »
At 635 USD maybe it's an overkill, but there are by far costly alternatives in desks.
This made me think I wouldn't get used to standing desks..., I prefer to stretch a while, then get back to work.
Working on
- Custom keycaps
- Boobiecaps
- Others
Offline keymaster
  • Topre Revolution Theorist
« Reply #2 on: Wed, 01 May 2013, 13:47:21 »
These things are usually insanely priced because they tend to be purchased by medical facilities (hospitals, doctor's offices). I can imagine something like this could be put together by for ~$100 by someone that's good with their hands.
Offline SmallFry
« Reply #3 on: Wed, 01 May 2013, 14:14:51 »
I thought about modifying a chair to accept an ergoDox to it by having almost another layer platter that I weld to the chair while I bolt the rest of the case together. Seemed plausible to me.
Offline Lanx
« Reply #4 on: Fri, 03 May 2013, 05:46:37 »
my work desk is consisted of 1 ergotron keyboard arm and 2 monitor arms, they adjust perfectly, but i almost never adjust them anymore since they're always in a perfect position.
Offline dndlmx
« Reply #5 on: Tue, 14 May 2013, 19:45:14 »
What a dope idea. I use an Ergotron MX for my monitor, I got it for super cheap. It'd be sweet to have my keyboard suspended too, tilted at *just* the right angle. Maybe you could use a monitor arm somehow, if the keyboard-specific products are too expensive.
Offline Lanx
« Reply #6 on: Wed, 15 May 2013, 14:59:16 »
the ergotron keyboard uses the exact same ergotron arms, only the mounting head is different. but the biggest cost is the keyboard mount tray.
Offline dndlmx
« Reply #7 on: Wed, 15 May 2013, 15:09:51 »
Surely one could make a tray, with a nice piece of metal, drill some VESA-sized holes. Crank the arm resistance just right...
Offline Lanx
« Reply #8 on: Wed, 15 May 2013, 20:40:13 »
you talking about the ergotron arms? i don't know about the MX, but the i know LX has about a 5lb weight requirement or the arm pops up, so yea need the tray to be kinda heavy, but i guess any material you use, if it's gonna be keyboard sized it'll be heavy enough.
the keyboard tray is small btw. it perfectly and i mean within 1mm fits my kinesis so 104 ppl are gonna have spillage. also the slide out mouse pad area is pathetically small, i pull that area out and slap my double sized mouse pad on it. oh i also had to mod the other side and have a chunk of metal hanging out so my nostromo has a place to sit, it's actually a piece of of a case and it's strong.
you can adjust the resistance in the MX arms? that's cool, the LX you can only adjust the head resistance.
Offline Mandolin
« Reply #9 on: Wed, 15 May 2013, 21:01:47 »
I just ordered the ergotron LX desk arm for the monitor, and I think the kb would need a wall mount or something, or a double stand. They're sweet. I'm just worried about my troublesome neck posture, more than hands. It aches so badly that I would make the most out of it. I just love them by their design too, but the neoflex are more limited than the LX series. I like the latter most.
I just don't make sense out of the standing desks, but I think I'd need to try it or I'm just too lazy to work standing.
Working on
- Custom keycaps
- Boobiecaps
- Others
Offline Lanx
« Reply #10 on: Wed, 15 May 2013, 22:16:43 »
a good headrest helps immensly for me, mine is fully adjustable mesh fabric, i can sit in this thing all day, but i cramp and cry if i have to drive for more than 2hours..., guess i just don't like car headrests.
oh and ergotron has a neoflex version for an underdesk mount, but i don't like the neoflex, that line has like nearly zero adjustability, i have a neoflex deskmount on my wifes rig and it's so un ajustable, it's just used so that there's more deskspace lol. i gave her a dual setup so the main is on a lx mount, and that adjusts really well.
Offline RougeR
« Reply #11 on: Wed, 15 May 2013, 23:32:39 »
something like this is just as good if sitting
repost from other thread, also the ones linked are pricey
since i have a typing and gaming board, when i have the money/moveout/whatever i wana ergo up my desk with stuff like this, will be so much better than lifting the boards over each other, and will look much cleaner + ther ergo benefits.
filco + mouse on the desk
m15 + trackball below the desk
http://www.ergodirectusa.com/Ergonomic-Adjustable-Mouse-Tray-p/s120.htm
http://www.ergodirectusa.com/Comfort-Keyboard-Big-Board-Keyboard-Tray-p/2100.htm
http://www.ergodirectusa.com/VIA-Voss-Mid-Back-Mesh-Task-Chair-p/voss.htm
Buckling spring warrior!
Offline dndlmx
« Reply #12 on: Wed, 15 May 2013, 23:50:08 »
MX has two adjustable places. The spring tightness (head) and the elbow. I have no idea what the minimum weight is. But my U2412m is extremely light, compared to the previous 27-incher I busted.  :rolleyes:
Offline Lanx
« Reply #13 on: Thu, 16 May 2013, 04:08:05 »
oh i take that back you can adjust the elbow in LX as well, i just haven't done it, since i got it that i forgot it was even there, heh, till you pointed it out.
