Author Topic: Keyboard with increased keycap spacing or larger kecaps  (Read 4093 times)
Offline hashish
« on: Tue, 30 April 2013, 10:14:32 »
Does this exist, I keep finding my self hitting adjacent keys. I have bigger hands, but not the biggest. I do like some RD keyboards that have larger keycaps and spacing between the keys. I tried searching, but I couldn't find any answers. Any advice or a nudge in the right direction would be appreciated :)
Offline esoomenona
  • Gnillort?
Re: Keyboard with increased keycap spacing or larger kecaps
« Reply #2 on: Tue, 30 April 2013, 10:16:45 »
Also, you might considered a DSA cap set. They are all the same profile, and much shorter, thus end up being wider and probably easier to type on for you.
Offline hashish
« Reply #3 on: Tue, 30 April 2013, 10:28:34 »
I did find info on the DSA cap set. Are there issues with them not being sculpted?
I did search oversized keyboard but I just got large lettering, rather than keycaps.
Offline esoomenona
  • Gnillort?
« Reply #4 on: Tue, 30 April 2013, 10:30:04 »
Those keycaps look much larger than normal to me. For instance, you can see the image of a guy's fingers over one of them.
DSA not being sculpted? How do you mean?
Offline ITzNybble
  • Formerly curro123083
  • Nibble or Nybble either way it sounds delicious!
« Reply #5 on: Tue, 30 April 2013, 10:32:07 »
You could also just do a typing test throughout the day, it all comes down to muscle memory, if you don't like my scientific answer then i would say DSA caps are your best bet as far as I know.
WASD V1 Custom - MX Blue
Custom Miami QFR - MX Green
Handwired Redox-Manuform - Box Pink/Box Navy
KBD67 MKII PolyCarbonate - Gateron CJ
Offline hashish
« Reply #6 on: Tue, 30 April 2013, 10:37:14 »
They are not angled for each row. All of the keycaps have the same profile/angle to them.
Offline esoomenona
  • Gnillort?
« Reply #7 on: Tue, 30 April 2013, 10:40:24 »
That's right, they aren't. It's been said that the angle of them is unnecessary and dates to a time when they used to need that angle.
Offline hashish
« Reply #8 on: Tue, 30 April 2013, 10:44:35 »
Thanks, I type all day long so I have the muscle memory. The top of the keycaps are just too small that my large finger ends up slipping off and hitting an adjacent key. I could try PBT keycaps because they typically have a rougher surface with more friction.
« Reply #9 on: Tue, 30 April 2013, 10:46:50 »
That's not necessarily true. My Klaxon set has a rougher texture than my Imsto Cherry caps right now. It depends on the mold more than the material.
Offline hashish
« Reply #10 on: Tue, 30 April 2013, 10:47:09 »
I have a QFR and a Leopold TKL, have you used DSA's with any standard TKL? I think I missed out on the group buys, but I inquired about extra sets.
Offline esoomenona
  • Gnillort?
« Reply #11 on: Tue, 30 April 2013, 10:49:04 »
I haven't used DSA ever, but I am eagerly anticipating the arrival of my DSA Retro set.
Offline hashish
« Reply #12 on: Tue, 30 April 2013, 10:59:12 »
I am jealous.
« Reply #13 on: Tue, 30 April 2013, 11:00:50 »
TechKeys will have some Retro DSA leftovers I think and there's a rumor that more DSA caps are incoming, keep an eye on the classifieds ^__^
Offline Dubsgalore
« Reply #14 on: Tue, 30 April 2013, 11:02:46 »
I just missed out on getting some DSA...maybe i should have gotten some..
« Reply #15 on: Tue, 30 April 2013, 11:08:44 »
Tech Keys will have leftover Retro DSA sets and Funkymeeba/meeba will be coming out with some DSA sets SoonTM :D
Offline Dubsgalore
« Reply #16 on: Tue, 30 April 2013, 11:11:02 »
That's what i was talking about :)
i could have got some with him
« Reply #17 on: Tue, 30 April 2013, 11:11:35 »
Pretty sure you can still get some. But you'll have to ask him
Offline hashish
« Reply #18 on: Tue, 30 April 2013, 11:47:41 »
I messaged samwisekoi from the unpaid extras thread in the GB forum.
Offline Grim Fandango
« Reply #19 on: Tue, 30 April 2013, 16:34:25 »
Bigger keys may be more of a hassle than you might think. You have probably built up a lot of muscle memory with the current keysizes. Changing those sizes and distances may be annoying.
Alternatively, you could go for a heavier or more tactile switch. Buy I imagine you have tried this already. Personally accidental keypresses are only an issue for me when I am using reds. I thought I would get used to it, but it remains a problem, and it is one of the reasons why I sold my board with reds.
