Author Topic: Introducing "More" (a.k.a. spoilers)  (Read 96181 times)
Offline The_Beast
  • I like wood ಠ_๏
Re: Introducing "More" (a.k.a. spoilers)
« Reply #50 on: Wed, 01 May 2013, 10:54:03 »
Can some kind of check box to added so that all images show all the time? Or they just are a "show image" but only when it's in quotes?
Offline esoomenona
  • Gnillort?
« Reply #51 on: Wed, 01 May 2013, 10:55:25 »
They should only shrink down to "Show Image" when quoted. If you see them other places, it's either the doing of the poster or a bug.
Offline rknize
    • metaruss
« Reply #52 on: Wed, 01 May 2013, 10:58:36 »
Show/Hide is a contender.  How about "Show More" and "Show Less"?
Whatever is decided what code will we use or does it matter?
Don't want posts to get broken in the future.  ;D
I think we are ditching the "fold" name, so stick with the "more" tag.  The post editor will use the new tag.  I also updated the OP when I switched it over.
Russ
« Reply #53 on: Wed, 01 May 2013, 11:01:57 »
thank you for getting this all worked out...I usually just type tags...and i didn't think to read the OP  :rolleyes:
Offline reaper
« Reply #54 on: Wed, 01 May 2013, 23:14:58 »
Cool stuff indeed.  Thank you russ!  :)
Din Eli
Offline rknize
    • metaruss
« Reply #55 on: Wed, 01 May 2013, 23:33:37 »
OK, "url"-wrapped images that are embedded in quote blocks should now collapse as expected.  It's a bit frail thanks to HighSlide, so LMK if you see anything bizarre.
Russ
Offline WhiteFireDragon
    • youtube
« Reply #56 on: Fri, 03 May 2013, 01:20:30 »
I was wondering what all these more icons were. They came out of nowhere, and lot of them too. But I'm not sure "more" is the most appropriate word. More what? Money? I agree with changing it to expand.
Offline rknize
    • metaruss
« Reply #57 on: Fri, 03 May 2013, 11:27:59 »
Noted.
Russ
Offline SmallFry
« Reply #58 on: Fri, 03 May 2013, 15:13:50 »
It seems (at least to me) that the images in quotes are reversed, as seen here. The text for the thing is correct, however the image displays while in quote. I'm hosting at Picasa WebAlbums which have a format of https://lh5.googleusercontent.com/-d3JtCAvcrYw/UYL_vtUYqfI/AAAAAAAAA8A/zbQ9tZoSzgQ/s912/DSCF2201.JPG if that will help you. :)
Offline esoomenona
  • Gnillort?
« Reply #59 on: Fri, 03 May 2013, 15:14:56 »
Doesn't show for me.
Offline rknize
    • metaruss
« Reply #60 on: Fri, 03 May 2013, 15:24:16 »
Please take a screenshot, because I don't see what you are referring to.
Russ
Offline SmallFry
« Reply #61 on: Sat, 04 May 2013, 15:20:18 »
Offline juju___mk
« Reply #62 on: Mon, 07 March 2022, 19:01:54 »
Testing!
Offline arr1
  • Ñ supporter
« Reply #63 on: Tue, 27 December 2022, 05:54:31 »
PANTONE 11-0601 TCX: Bright White[/size][/center]
